Electronics cpu fan with bare leads
Discussion in 'Modding' started by fartonmyear, 29 Jul 2005.
  1. fartonmyear
    fartonmyear What's a Dremel?
    16 Jul 2004
    i ordered these http://www.svc.com/pahywabefb1.html and they don't come with 3pin connectors. if i cut off a 3-pin connector from a space case fan such like this should it be fine? and the duct tape.
  2. bassboi72
    bassboi72 My dremel is broken.
    21 Jul 2003
    indeed it should... i'd put electrical tape just to be sure ;)
  3. H311R4153R
    H311R4153R What's a Dremel?
    28 Mar 2005
    Soldern them and put some heatshrink on.
  4. Skylined
    Skylined Minimodder
    3 May 2003
    This.
    But why don't you just buy the nylon conector and metal terminals, you crimp it and put them into the connector? ;)
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    You didn't spot the Accessories? :p
  6. fartonmyear
    16 Jul 2004
