CPU Fans
Discussion in 'Hardware' started by Pooky, 4 May 2004.
  1. Go4t
    Go4t i
    13 Dec 2003
    get the waterblock and just have it sitting in the case not mounted
  2. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Sure you can, most systems have some sort of drainage point, usually a drain valve on the rad, and once you've drained the system (i.e. leaving the pump running while all the water goes out into a basin) then you can take apart the components relatively easily without extreme spillage. It doesn't really matter that much if you get a little bit of water on your computer anyway, as long as it's off and you dry it thoroughly before you turn it back on again :D
