CPU CPU/memory question
Discussion in 'Hardware' started by Siwini, 8 Dec 2011.
  1. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    So my CPU died. I have spoke with Intel representative and he asked me what memory I was using. I said I have two RAM kits; 1333 MHz 8GB & 8 GB 1600 MHz. He stated that none of their processors are compatible/ made to work with 1600 MHz RAM. Only Intel’s new* released 2011 CPU socket support up to 1600 MHz memory. He said that CPU will most likely fail if you were to use anything but 1333 (1.5V) MHz RAM. According to him none of Intel’s CPU is made to work with 1600 MHz (except 2011). Now here is question than why would anyone including Bit-tech buyers build guide year after year recommended us 1600 MHz RAM way before 2011 socket was out?
    Ratchet219 likes this.
  2. Lord-Vale3
    Lord-Vale3 His Tremendousness
    1 Dec 2009
    He gave you an odd answer imo. I'm on Lynnfield, an i5-750. So Intel rates it as compatible with 1333. I have 1600 RAM, but it downclocks itself to 1333.
    This happens with all 1600 RAM when you initially build the system, as the motherboard automatically runs them at 1333. In order to achieve 1600, you must overclock.
    So you're RAM may be capable of 1600, and may say so on the package or whatever, but it doesn't achieve that speed unless you overclock, and it is still perfectly compatible with all pre-socket 2011 chips.
    'Most likely fail' is silly.
  3. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    The intel rep was talking out of his a$$. The only way memory could have anything to do with a dead CPU is if you cranked the mem voltage up past 1.65v
    Siwini and Ratchet219 like this.
  4. GoodBytes
    20 Jan 2007
    Ok the reason is that the Intel Core i7 800 series supports up to 1333MHz, the Core i7 900 series like I have, supports up to 1066MHz.
    The thing is, when you use eXtreme Memory Profile, the motherboard clocks the system bus to try and achieve the memory clock rate. In my case 1333MHz (doesn't go to 1600MHz, unless I manually overclock). I believe Intel considers as an overclock, and voids the warranty of the CPU, even though you are not touching voltages. As mentioned, as long as your RAM doesn't pass 1.65V you are good. And that should be a no fear situation, because you use 1.5V memory (right?).
    OR simply, it was some cheap excuse to not cover you. If it was not the memory, they'll probably tell you that you didn't use Intel official heatsink, or Intel own motherboard or some potato like that.
  5. Siwini
    14 Sep 2010
    Yes I use 1.5V however my 1600 MHz is rated for 1.6V. Intel said they will process this RMA but advised me on not using 1600 MHz. Why did I buy this if I cant use it's full power? Or can I:confused:
  6. Pookeyhead
    30 Jan 2004
    I've been using a i7 920 with 1600MHz RAM for 3 years now. Absolutely no problem.
    Siwini likes this.
  7. Ratchet219
    Ratchet219 What's a Dremel?
    9 Aug 2011
    Looking at that link it says "Intel XMP certified" so 1600 is not overkill.
    Siwini likes this.
  8. Siwini
    14 Sep 2010
    Did you overclock CPU or used XMP profile?
  9. Pookeyhead
    30 Jan 2004
    Everything was overclocked... but you don't have to overclock anything. The retail chips have unlocked memory dividers... I just selected 1600MHz from from the BIOS manually, or you can just select XMP and it sets it.
  10. Bituser
    Bituser 64 Gigglebytes
    13 Aug 2011
    Wow, now I am confused. I am looking at buying a new computer. Should I not stick 1600mhz RAM in?
  11. Pookeyhead
    30 Jan 2004
    On a 1366 i7? Sure, of course you should. Just read this first, and pay attention to the bit about QPI/Incore voltages. Keep them within 0.5v of CPU VCore volts and you're fine.
  12. Bituser
    13 Aug 2011
    Sorry, Core i5 2500k.
  13. Pookeyhead
    30 Jan 2004
    Ahh... ok. It still shouldn't be a problem.
  14. Bituser
    13 Aug 2011
    Cool, thanks. I didn't even think that it would possibly be an issue. What about the people using 1866 and above?
  15. GoodBytes
    20 Jan 2007
    With the second gen Core i series, you should have no problem with 1600MHz, just set the XMP profile, and you should be good to go. If you want faster memory you need to do some overclocking.
    In my case with the first gen Core i series, XMP boost my CPU to support 1333MHz. Now if I overclock, I can easily go to 1600MHz, so I have that room, without overclocking my memory beyond what the manufacture designed frequencies.
