Build Advice CPU / Mobo Upgrade??
Discussion in 'Hardware' started by adsuk, 2 Aug 2011.
  1. adsuk
    adsuk What's a Dremel?
    2 Aug 2011
    Hello guys,
    I'm Adam and im pretty new to computer upgrading etc so go easy on me :) just looking for a little advice please.
    Right, I have a packard Bell intel core 2 quad Q8300 on a EG43M Motherboard.
    Now I know I am VERY restricted to what I can upgrade on this as its prebuilt (dont shoot me had it about 2 years I know I am silly), However I brought a GTX 560ti from Scan and a 650w PSU a few weeks back.
    I use Microsoft’s flight simulator, and have been told I am bottlenecking quite badly with this as i am still getting poor FPS in flight simulators.
    I've been advised that flight Sims run mostly off CPU not GPU, so how can i go about upgrading this?
    Would I be right in saying I could buy a case and then a CPU & Motherboard and id be able to do this??
    btw, ive looked on Scan and found a prebuilt over clocked bundle,
    Smart - Intel Core i5 2500K - Over clocked to 4.5Ghz - Updated August.
    Does this sound viable or am I way off?? Also wasn’t looking to spend any more than around £350 if that’s possible??
    Thanks a lot, Adam.
  2. fata1_666
    fata1_666 ...
    13 May 2010
    High cpu clock into the 3 ghz and a tri core as most games currently dont support much past two may be three cores. also maybe the hard disk could throttle perfromance think about a fresh new disk with larger cache, rpm.
  3. stefan442
    stefan442 Minimodder
    14 Mar 2011
    for 350 you could buy an antec 300, i5 2500k and an asus p8p67 pro.
    but.... how much Ram do you have? and what is it?
  4. Bede
    Bede Minimodder
    30 Sep 2007
    I wouldn't buy the OC'ed bundle, you don't need that much performance and it will probably have very high voltages running through it which will reduce the lifespan of your CPU/mobo.
    MSI p67-gd53 and i5-2500k is a fairly standard combo which works well. Probably worth getting new RAM, the stuff that came with the prebuilt could be a bit rubbish. 2x4gb of 1600mhz should do you fine :)
  5. fata1_666
    fata1_666 ...
    13 May 2010
    Get yourself an amd cheap cheerfull
  6. adsuk
    2 Aug 2011
    Hi guys,
    thanks for the replys,
    It actually works out cheaper for me to get the overclocked bundle to be honest, this is the system if i went for it ;
    Case:Coolermaster 690 II Advanced
    PSU: 650W Hale Modular
    GPU: GeForce GTX 560Ti, 1gb.
    CPU:Intel Core i5 2500k 3.3ghz overclocked to 4.5ghz ,
    Cooler: Corsair H60
    Mobo: MSI P67A-G45 Intel P67 Chipset
    RAM: 4gb DDR3 1600Mhz. Corsair.
    How does it look??
