CPU pick
Discussion in 'Hardware' started by aevitas, 22 May 2005.
  1. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    Hey,
    I am searching for a faster CPU atm. And I was thinking between these two:
    AMD Athlon64 3800+ Venice
    AMD Athlon64 3700+ SanDiego
    Which one should I pick? Cause they aren't that much different in pricechecks..
    :idea:
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Venice = 512k and 2.4ghz (for 3800)
    Diego = 1mb and 2.2ghz (for 3700)
    Grab the diego. It'll do 2.4ghz easy. Extra 1mb cache will help out in games too :D
  3. webbyman
    webbyman Hax.
    7 Oct 2004
    san diago! no dought about it...
  4. hughwi
    hughwi Minimodder
    23 Dec 2003
    Get the san diego, then just bump it up by 200mhz and you have one amazing chip!
  5. aevitas
    6 Mar 2005
    Ok..
    And would a 3700+ Clawhammer be even better? :confused:
  6. Pointy Burdz
    Pointy Burdz What's a Dremel?
    24 Jul 2004
    No unless you get a mega clocker, San Diego is the new kid on the block and has extra features
  7. hughwi
    hughwi Minimodder
    23 Dec 2003
    San Diego is the new core, Clawhammer is the first (and oldest) core, get the San Diego :D You WONT be dissapointed!
  8. mime genocide
    mime genocide What's a Dremel?
    2 Sep 2004
    if you go below a 3500 the venice is a good core.
    the 3000 is a good deal
  9. SAS91
    SAS91 What's a Dremel?
    22 May 2005
    hi aevi ^^
    Yea SD core will be much better and if you decide to go water cooling and Oc you will easily get 2.8ghz out of that.
