Cooling CPU Temp
Discussion in 'Hardware' started by stewe151, 11 Mar 2002.
  1. stewe151
    stewe151 Stress Personified
    9 Mar 2002
    its a diamondmax VL 40.09GB 5400RPM
  2. Renko
    Renko What's a Dremel?
    19 Feb 2002
    VERY quiet drives but....
    not only is it annoyingly quiet but aparently the system that limits the noise also affects the performance. :mad:
    Found a hack for this the other day but not tried it yet, take a look at http://www.overclockersrip.com/articles/maxtor.shtml
  3. weazel666
    weazel666 What's a Dremel?
    12 Jan 2002
    it does work i've tryed it ... it really does makes my drive go slower but silent, or as quiet as you can get it .. so changed it back
  4. Sowler
    Sowler What's a Dremel?
    22 Mar 2002
    I got that board
    Hey stewe I got that board the ECS K7VZA, I now have my lovely abit kT7A but I do believe you can overclock on it cos I cud get my duron 800 up to 896 (ok not much overclock but i wasn't looking for an ocing board at that time) The option isn't in anything abvious but if you have a look through ur bios you should find it. Good Luck
    Sowler
  5. howesey
    howesey What's a Dremel?
    17 Aug 2001
    If you ever see the main controller on a supercomputer you will notice it sits in liquid nitrogen, all the circuits. This is because superconductors are needed as the trhoughput is massive.
  6. Lord_Vheox
    Lord_Vheox What's a Dremel?
    6 Feb 2002
    Max temp on a 1.2 T-Bird is not 70. I used to overclock to 1.45 with a Dragon Orb 3, and it worked just fine to temps up to 76-77... With my watercooling kit im down to 50 (and thats cos i got a bad in flow, and its always hot in my room.)
