CPU CPU Temperature Confusion
Discussion in 'Hardware' started by TheManicGibbon, 28 Mar 2010.
  1. TheManicGibbon
    TheManicGibbon I have no idea what's going on
    12 Aug 2009
    Hi
    I use the latest versions of CoreTemp and SpeedFan to monitor my CPU temperatures, but the CoreTemp readings are always 10 degrees C above SpeedFan's.
    Which program is correct?
    I have a Q6600 2.4GHz with the stock cooler.
    EG- Core 0
    SpeedFan = 39 C
    CoreTemp = 49 C
    These are idle temps.
    Thanks
  2. Krikkit
    21 Jan 2003
    Using the stock cooler I'd be tempted to say CoreTemp is giving a more realistic temperature, although all internal temp sensors are just guesswork really.
  3. masterjonny
    masterjonny What's a Dremel?
    5 Mar 2010
    Throw an extra spanner in the works and download real temp. See which two look similar, leaving you with the one which must be anomalous :)
  4. TheManicGibbon
    12 Aug 2009
    I couldn't get RealTemp to install but Hardware Monitor from the same people that make CPU-Z confirms the readings of CoreTemp.
    Thanks for the help. :)
