CPU CPU temps = BSODs?
Discussion in 'Hardware' started by fingerbob69, 28 Feb 2015.
  1. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    I've recently been getting an increasing number of game hangs, black screen hangs and BSODs.
    The various bug check codes came up with both driver and hardware failure a possibility.
    So, I've tested the RAM (7passes/5hrs memtest).
    I've replaced the gpu driver 3 times and am currently back to 14.4
    Via HWinfo64 the PSU ...inparticular the 12v seems solid. GPU temps move from 34c to 75c ...no problem.
    But what I am seeing is the cpu temps report under load.
    the 0.1.2.3 core temps are topping out at 99c with 0 and 3 going passed that and reported as thermal throttling.
    Strange thing is, since going back to 14.4 ...no crashes.
    Am I right in thinking that the cores are getting too hot ...and that a re-seating of the cooler with some fresh TIM should sort it?
    The system is the one below with the cpu/cooler/mobo being completely unmolested since build.
  2. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    This would be the 1st thing I would be trying with those temps.
  3. fingerbob69
    5 Jul 2009
    Yeah ...it's just given this ...i7-920 D0 oc@3.6ghz ...I wasn't sure if those temps were normal!
  4. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    Definitely if it's throttling...
  5. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Nope, those are definitely high. Intel list the 920's Tcase Max temp as 67.9°C. The Tj (internal temperature, the one you can measure) will be higher than that, but not all that much. Keeping Tj below 80-85°C is generally a good idea.
    Either your HSF has come loose, the thermal compound has degraded, or the heatsink is too small (unlikely but possible. It would need to be worse than the stock heatsink).
  6. fingerbob69
    5 Jul 2009
    Thanks folks ...esp. edzieba for that info. New TIM and a reseat it is.
  7. elise_s1
    elise_s1 What's a Dremel?
    26 Jan 2015
    run a temperature monitor and check how big a gap is launching Prime 95.
    if temperature increase of over 20 C within one second it means heat can't reach the heatsink (TIM- bad seat related)
  8. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I used to have a i7-920 in a really starved desktop/media centre case, and that never got nearly that hot at 3.6. I would reseat the hsf with new thermal paste as my first port of call. You might find the thermal paste has turned hard/cracked/old and thus not working great.
  9. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Not wanting to argue or anything, but is it even possible to measure the Tcase without using a thermal probe, isn't Tcase the temperature in the middle of the IHS ? I thought most measurements use TJmax, or in other words the readouts from each core.
  10. edzieba
    14 Jan 2009
    No, it's not possible to measure Tcase without an embedded probe, which makes it quite annoying that Intel do not specify a Tjmax rating.
  11. fingerbob69
    5 Jul 2009
    Just to update...
    New TIM and a real good clean! =
    Idle temps @ 40-42c
    Gaming temps @74c max
    Prime95 a steady 85c across all 4 cores.
    I think there might be a software issue still what with all the crap I downloaded to help try and find the issue ...lots of bits of drivers etc everywhere ...so I'm thinking an OS re-install might be a good idea.... otherwise all is good :thumb:
  12. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    What's the ambient room temp like as 40 idle/85 load still seems a little high to me for what is supposedly a decent cooler.
    Although it might not be too far up the scale by the looks of this.
  13. fingerbob69
    5 Jul 2009
    You think?
    Ambient is about 20-21c.
    The paste is brand new ...temps should drop a few degrees as it cures ...or so I'm given to understand.
    Either way... idle temps are down 20% and load temps 25%. I think I'm happy with that.
  14. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    I must agree that it's still a bit high - are you recirculating any hot air?
    What voltage are you pushing for 3.6?
