Cooling CPU to hot?
Discussion in 'Hardware' started by cire9753, 22 Aug 2006.
  1. cire9753
    cire9753 What's a Dremel?
    16 Aug 2006
    idle is about 40-45C usually and it used to idle 55C with stock so i got a new zalman cooler but 40C+ still seems a bit high but its always stable. P4 3.0ghz HT Prescott
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    That's fine don't worry about it. 65 under load's perfectly acceptable :)
    Celcius, BTW.
  3. samkiller42
    25 Apr 2006
    I had a P4 3.2GHZ and that would reach 65 while playing Roller Coaster Tycoon :worried: , that was on Intel Stock, but in idle it would hang around 40, and boot up would be around 50.
  4. Glider
    Glider /dev/null
    2 Aug 2005
    Yeah, thirded... Don't worry about those temps...
    What I find mostly, is that the temps you read on enthousiast fora like these are 5 or so degrees below what I get... But I don't have the sound of a vacuum cleaner next to my head... ;)
  5. Nexxo
    23 Oct 2001
    This useful reference here (bookmark it, you'll be glad you did. Trust me) states that the maximum safe temperature for a P4 Prescott 3Ghz is 67.7C.
    Specs dictate that if the on-Die thermal probe reaches approximately 135° C (its catastrophic temperature), the CPU will automatically shut down and "the system bus signal THERMTRIP# will go active and stay active until the processor has cooled down and a RESET# has been initiated."
    However, it's unlikely the CPU will reach its maximum power dissipation since the processor will throttle down the CPU speed as it reaches past certain temperatures. And in the event of a catastrophic cooling failure (i.e. leaving off the heatsink), it would simply shut down the CPU.
