CPUFAN1 Problems
Discussion in 'Tech Support' started by Major, 14 Nov 2007.
  1. Major
    Major Guest
    Hi all,
    So I've installed my heatsink, PC is running smoothly, but the only way it's running it with the stock fan plugged into CPUFAN1 socket, and if its not the PC will not stay on for more than 4 seconds.
    I have no need for this socket, but as it's detecting there is no fan connected to it, it shuts down.
    I also cannot plug any fans into it as it's a 4 pin connection, and all my fans are 3 pins.
    The mobo is AW9D Max.
    TIA
    Major
  2. Computer Gremlin
    Computer Gremlin What's a Dremel?
    11 Sep 2006
    Use the uGuru utility and disable the auto shutdown if low RPM is sensed from the CPU fan. Look on page 3-7 on the BIOS Setup in the motherboard manual.
  3. Major
    Major Guest
    It worked, thanks. :)
  4. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    you'll also find that a 3-pin fan plug fits perfectly onto the 4-pin header.
