Modding Crack out the dremels
Discussion in 'Modding' started by darkvirus999, 26 Jul 2007.
  1. darkvirus999
    darkvirus999 beware of hackers
    21 Jul 2007
    Crack out the dremel, ive got £2000:)D) to spend on a computer and case. Ive chosen the Lian Li PC-G70B
    Any 1 got any idead for the case i will be glad to hear them because im a bit stuck for ideas.
  2. darkvirus999
    21 Jul 2007
    The case is in black but the black images wernt very clear
  3. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    Start with something you like. Pick a function you want to add to the case (IMO the best "mods" start with that in mind), or a theme, or a certain look, or ...? This part is best done by you.
    What is the case being used for? Games / media / server / ?
    If it's for gaming start by picking an element from your favourite game.
  4. darkvirus999
    21 Jul 2007
    There is a design idea for the window the far right window is going to be meshed aswell, also is the fan hole
  5. darkvirus999
    21 Jul 2007
    Here is the finnal design
  6. jakenbake
    jakenbake full duplex
    5 Jun 2005
    everyone uses green plexi...
  7. darkvirus999
    21 Jul 2007
    ive had blue for the last 2 years so i fancied a changed an i didnt want red
  8. Vica
    Vica What's a Dremel?
    23 Jul 2007
    Green is good but I'm partial to red, think you need to do the green in the right shade to get a good look, with red its hard to go wrong in any shade.
  9. Tyinsar
    26 Jul 2006
    The concept looks fine to me but I think your scale is a little off. To me it looks like the drawing has the side fan too high and too much space below the front drive bays.
    I'd change the side to look like:
    Code:
    |             | |xx| |
    |             | |xx| |
    |             | |xx| |
    |----.        | |xx| |
    | xxx '-------' |xx| |
    | xxx .-------, |xx| |
    |----'        | |xx| |
    I think the fan would fit in better that way
    Additionally consider carrying that look to the front like it is on the top and side.
    As for the colour, whatever looks good to you - you'll be the one using this case. :thumb:
