Cooling Cracked the plexi on my block
Discussion in 'Hardware' started by yodasarmpit, 29 Mar 2004.
  1. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Fitted new barbs to my settup, but managed to crack the plexi on my northbridge cooler.
    Any way to fix this or does anyone know where I can buy a replacement plexi cover (waterchill chipset block)
  2. Risky
    Risky Modder
    10 Sep 2001
    in the first instance you should try http://www.asetek.com/ if you choose support, then technical spoort, they have a wen form to fill in for assistance.
  3. MadD_b0mBeR
    MadD_b0mBeR What's a Dremel?
    25 Oct 2003
    ouch ouch ouch ouch ouch... thats the pain that u can get with plexi. Brittle stuff it is, and doesnt like pipe-threads! ur only problem would be if it leaked, rub some silicone sealent into it top, bottom, sides, and u should be ok. Wont look **** hot, and ur still best off with a new top if there good on warentee.
  4. friskies
    friskies What's a Dremel?
    17 Nov 2003
    The pain! The agony!
    But i think u could fix it with some epoxy... Some types of epoxy are 16x the strenght of concrete. And there are types that are fluid-resistant
  5. tk421
    tk421 Idiot.
    15 Jan 2002
    ips Weld-on #4
  6. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    I had the miss fortune do bugger up my spiral by some over zealous tightening of the barbs. I got on the emails to D-Tek and a new top was dually sent in the post. On the new one there is plastic barbs (screwed in hand tight) held in now with araldite as the original silicone had become loose in installation. I then use plastic hose clips. Just use a bit of Vaseline on the barbs so that the hoses go on and off easier.
  7. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Check out my ghetto repair job. (will try to get a new top or block soon)
  8. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Arrrrrghhhhhh, Its still got a leak, I think I will just cover the whole block in silicon untill I get a replacement.....
  9. [GiB] Spawny
    2 May 2001
    I'm suprised you risked it :duh:
    Get the new one before you loose my than you can afford :thumb:
  10. Bugaloo
    Bugaloo What's a Dremel?
    27 Sep 2003
    what size are the threads on the replasement fittings? been thinking about upgrading my waterchillkit.
  11. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    3/8" BSPT
  12. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I meant to order a new block on Wednesday when ordering a new pump and additional radiator, but forgot. :duh:
  13. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    What I dont understand is why WB companies use plexi instead of lexan or polycarbonate (samething different name).
    It isn't that much more expensive, it is stronger, doesn't crack, it machines easily.......
    A piece of 3/8" lexan for a waterblock top would be nearly indestructable.
    Oh well, as long as I have to go to lan parties with my only rig, I'll be using air cooling, so I don't have to worry about cracked blocks myself.
    /rant
  14. Bugaloo
    27 Sep 2003
    thats the original thread size?
    blast, the webshop with the most fittings doesnt have brass fittings that size :wallbash:
  15. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    That was the original thread size, I got the barbs from www.coolercases.co.uk dont know if they ship abroad though..
