Modding Crap! Help!
Discussion in 'Modding' started by neverborn, 6 May 2004.
  1. neverborn
    neverborn What's a Dremel?
    6 May 2004
    Okay, so I installed some stuff. Like a lot.
    I'm thinking this is a power problem, but not sure.
    Out of 3 Speeze LED fans, two are tealish in color. Not sure if this is power or just crappy LEDs.
    Out of 4 Thermaltake CCFLs, two don't work. At all.
    The Nexus fan controller's LEDs light up, but knobs don't do anything.
    So I ponder if it's power or not.
    On Antec TruePower 550W:
    Power#1: DVDRW->DVDROM->HDD
    Power#2: CPU HS/F->ATI RADEON 9800XT
    Power#3: 4 CCFLs->2 Fans->Fan Control
    Power#4(FAN ONLY): 3 Fans.
  2. Go4t
    Go4t i
    13 Dec 2003
    which fans are plugged into the fan controller?
  3. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    Take everything out, then plug a few things in at a time and test as you go, should have been the way you did it to start with tbh.
    'doc
  4. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    That sounds like the best thing to do.
  5. Furymouse
    Furymouse Like connect 4 in dagger terms
    4 Feb 2004
    I am running alot more than that on a antec 430( I think )
    There might be some sort of a rail prob, or .......
    are there dedicated fan lines on that psu, cause on mine, if I used those on anything but fans they just wouldnt work
