Windows Crazy boarder when resizing windows!
Discussion in 'Software' started by culley, 7 Feb 2011.
  1. culley
    culley What's a Dremel?
    12 Jul 2006
    Its started happening 3 days ago, i have two windows 7 machines side by side and one does it and the other one doesn't.
    I have changed the theme, back and forth and no luck.
    I have never had this problem before lol and its really bugging me now.
    Windows 7 Pro
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    does it disappear, or stay there, once you have finished resizing?
    check the visual effects settings, which you will find under, advanced system settings/advanced/performance - settings
  3. culley
    12 Jul 2006
    Once i have finished resizing it goes away, i have checked in the advanced settings and the only thing that would remotely seem obvious is the boarder padding, which doesn't change it.
    The thing is though I haven't changed any settings before it started happening. i checked my settings against another win 7 pro machine and there are exactly the same.
    Crazy, i am tempted to just reinstall Windows lol.
  4. carpetmonster
    carpetmonster What's a Dremel?
    27 Jan 2011
    What about System Restore first of all ? If you have it turned on.
  5. kenco_uk
    28 Nov 2003
    It looks similar to unticking XP's 'Show Window Contents while re-sizing' setting.
    Try the setting here:
    Control Panel -> System -> Adjust Appearance and Performance of Windows -> Show Window Contents while dragging. (and -> Animate Windows when minimizing and maximizing).
