Crazy ! CPU !!
Discussion in 'Hardware' started by ComputerKing, 27 Jan 2007.
  1. ComputerKing
    8 Sep 2006
    Guys Just don't know !!! in every game I got this error but with different numbers but same idea
    so wtf this from !! I can't use my computer good any more it crash because of this
    so any Idea !! thanks I need quickly Fix :D
    Edit : after this happen : speed fan got crazy and read all things Zero ( 0 )
  2. spacemunkee
    spacemunkee What's a Dremel?
    17 Dec 2006
    Something to do with ati catalyst, maybe give the drivers a reinstall for your card.
  3. ComputerKing
    8 Sep 2006
    OK I will try now , BTW: I have another Q: what the safe and normal Ide temp for x1950xtx . mean what the normal temp for that card !!! thanks , Now reinstall and see !! Thanks
  4. ComputerKing
    8 Sep 2006
    NOOOOOOOOO .. I tried now to reinstall the driver and didn't work !! I still get same error !!! I use the newest driver 7.1 HELP plzzzzzzzzzzzzzzzzzz
    Edit : see what happen to speed fan !!
    OMG I can't control the card any more by ATITOOLS :wallbash: :wallbash: :wallbash:
  5. geek1017
    geek1017 What's a Dremel?
    6 Aug 2002
    Completely uninstall the driver, ATITool, and Speedfan.
    Install the latest driver with only the default settings.
    Fire up a game and see what happens.
    Then install stuff and overclock until it breaks again :p
  6. ComputerKing
    8 Sep 2006
    man tried this same thing still happen !!!
    I can't play :wallbash: :wallbash: :wallbash: :wallbash:
  7. Nexxo
    23 Oct 2001
    Uninstalling a GPU driver and reinstalling it is a precise ritual.
    1. Uninstall the driver and ATi tool.
    2. Restart the computer.
    3. The computer will now recognise the GPU card and ask for drivers. Install the new drivers now.
    4. Restart the computer again.
    5. Now test-run it, and install Ati tools if everything works.
    If it does not, I would look at re-seating the GPU just to be sure.
  8. ComputerKing
    8 Sep 2006
    Here we go !! this work , now ati tools back to control !!
    but the error still happen !!! and speed fan damge with the error !!
    so now still to fix that error !! it wired !! I never saw it in my life !!
    thanks . Wait for the help
    Thanks Nexxo u fix Ati tools now :D still fix the error , I want play :waah:
  9. Nexxo
    23 Oct 2001
    Set all the settings of ATi tool and the GPU drivers to default. Set Speedfan to monitor temperatures, but not control any fans.
  10. ComputerKing
    8 Sep 2006
    yeah I use speed fan for only monitor temperatures , and all things default now !! and still same problem . the error still happen when the game open after that the game crash !!! and no no overclock , every thing default ! still happen
    help , Please
  11. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    try the drivers that came with the card on the CD
  12. Maelan
    Maelan What's a Dremel?
    28 Jan 2007
    Do you have any spare GPU just to run a test and see what happens ?
  13. Springs
    Springs Boing boing
    29 Aug 2004
    just curious what OS u running? is it XP or vista? just woundering if you have the correct drivers for the OS
  14. ComputerKing
    8 Sep 2006
    its Xp sp2 I have the right driver !! I tried the cd driver !! same problem !!
    mm Another vga !! No I don't have I sold it !!
  15. Springs
    Springs Boing boing
    29 Aug 2004
    dont suppose u have tried the usualy virus/spyware scans just incase?
  16. ComputerKing
    8 Sep 2006
    yeah norton and adware and spypot !! they say my computer clean !!!
  17. Springs
    Springs Boing boing
    29 Aug 2004
  18. Glider
    Glider /dev/null
    2 Aug 2005
    Just a lucky shot, is the card OC'd in any way? and what are the temperatures?
  19. ComputerKing
    8 Sep 2006
    about OC no not yet !! the temp like 45 c !!
    I reinstall the .net and every thing they say !!
    same problem and now no antivirus I remove it same problem
  20. ComputerKing
    8 Sep 2006
    Bump for help . please I want play
