yar, it could be useful. If its a neat fit then I say go for it. I'm getting a nice tv capture card soon. the only reason I wouldn't put a console in there is cause its nice to be able to port away the smaller consoles at any time. I say go for it. I think it would make a cool stealth if people didn't even know there was a ps2 until you hooked up the controllers
What would be cool, but difficult is if you could make it like a slide out HDD. So if you want to take it with you you slide it out, and slip it into a box you make. The box and the PC would have a custom jack (you make) that all of the power, controlers, A/V etc go through to their separate actual ports that are actually on the PC or box. Just an idea....
OK... so I started the mod... NOT EASY. many wires that are rare need to be extended, and the DVD drive from the PS2 doesn't want to come out. Does anyone know where i might be able to find a tut of disassembly of the PS2?
Hey Fan Man, you are the forth Forumgoer that I have found in the Seattle metro area (Or approximately) Nice idea, but I would so much rather place every console that has fun games that are worth playing in one system... heheheheheheh, swapping between them would be annyong, but at least you could transport them all at once with relative ease
really? Bizarre What is your setup BTW? Heh, maybe all us Seattle Metro Area modders should have a convention
AMD Athlon XP 2700+, 2.16ghz, Asus A7N8X Deluxe, GeForce FX 5700 Ultra, 1.5GB DDR Ram, 120 GB Seagate, Enermax 2x2 Ultimate Fan Controller, Sony DVD-R/CD-R/CD-RW, Chieftec case, and many, many blue LED fans. <--- just like that little dude. ok.... not the same... but close enough. O... and one more thing... THE PS2 M/B IS TOO BIG! it doesn't wanna fit on the bottom of my case. It makes me stab. *sigh* now I gotta put my whole PS2 back together again.
ouch ouch man all that work fo nothing im grieving with u man i was looking forward to see it finished
