Crazy ethernet light.
Discussion in 'Tech Support' started by Ryu_ookami, 8 Feb 2008.
  1. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    Hi whats the best and easiest way to tell who is connected to my network. The reason I ask, is because for the past day my PC's been running so slowly its unreal (its taken 30 minutes just to open bit-tech) however when I look at the modem/router I have the Ethernet port light is constantly flashing. I know none of the other PC's are connected to the network at the moment (I've turned them all off) so it makes no sense for it to be going as crazy as it is I'm in the process of running a full virus scan or I will be after posting this. I've checked processes and theres nothing strange there. so any ideas would be gratefully appreciated.
  2. ch424
    ch424 Design Warrior
    26 May 2004
    Start > Run > cmd > netstat
    See if anything comes up there?
  3. Ryu_ookami
    11 Mar 2004
    about 3 pages of stuff came up some that I know I'm definitely not connected to so later on I'm going to shut all the internet pages I have open down and reset the router and then try it again and see what happens thanks for the reply I'd forgotten all about netstat.
  4. johnmalc
    johnmalc That shouldn't happen....
    7 Jul 2007
    Doesn't your router have a page saying who/what is connected to it? Mine does.
  5. lworbey
    lworbey What's a Dremel?
    23 Nov 2007
    Sounds like you might have something suspicious sending stuff out to the internet...
  6. monkeybone
    monkeybone What's a Dremel?
    28 Jan 2005
    Depending on the router you are using it should allow you to view all connected mac addresses whether it's via wireless or wired. Typically it would give you the pc name, mac and ip address assigned and in some cases ip lease time.
    Monkeybone
