Networks Crazy Network Setup
Discussion in 'Tech Support' started by Omnituens, 26 Jan 2012.
  1. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    Howdy bit-tech! Time to put your brains in gear!
    I have just moved into a houseshare and we are all connecting wirelessly. That's cool, I have a wireless card built into my laptop. However, my PC does not.
    Now I don't mind picking up a wireless network card/adaptor for my rig, its just that it doesn't completely solve my problem.I use my laptop as my second monitor and stream movies/programs/whathavetyou while I'm gaming. This would be detrimental to the network as a whole.
    Ideally what I would like to have is my laptop and rig all wired to a router in my room, then have that router... route the internet data via wifi. I don't know if this is even possible, but it would be the best solution as then my streaming would not interfere with the other peoples wifi.
    Any suggestions? I have a Netgear 615v9 spare to flash with any firmware that might be required. Both machines are running Win7.
  2. j0rd
    j0rd FLOSS folder
    13 May 2011
    use an ethernet - wifi bradge
  3. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Configure your Netgear 615 as a wireless bridge to the Wifi and connect your laptop and PC with wires.
  4. Omnituens
    5 Apr 2006
    Cool, I'll give it a try. Google informs me I might need to reflash the firmware on this netgear to do that.
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    Just don't enable NAT on teh Netgear as you will also be using NAT on the internet router. Double NAT'ing will just cause problems.
  6. Omnituens
    5 Apr 2006
    OK, first off I was totally wrong about what this router was, turns out it was a D-link after i unpacked it from storage lol.
    I flashed it with DD-WRT firmware and follow 2 guides - one to try and turn it into a repeater... which failed. Then I tried turning it into a client... which failed. I followed the guides to the letter, but the D-link is not receiving a WAN IP address.
    With some telnetting I have finally got admin access to the actual AP point. I'm fast running out of ideas, as networking is not my strongpoint.
    I have followed these guides:
    http://www.dd-wrt.com/wiki/index.php/Wlan_Repeater
    http://www.dd-wrt.com/wiki/index.php/Client_Mode
    PROBLEM SOLVED - the AP router was telling me it was using WPA encryption, after telnetting into it I discovered it was actually using WPA2. Done, all set up now!
