Displays Crazy unexplainable Ati 5870
Discussion in 'Hardware' started by SmilerAl, 7 Jan 2011.
  1. SmilerAl
    SmilerAl Terminate with extreme prejudice
    6 May 2010
    After noticing my GPU temps were a bit high for my liking whilst on idle, I investigated by looking into MSI Afterburner, here's what I found.
    I'm not really doing anything to affect this, right now too busy doing revision to actually game or put any other sort of pressure on the GPU, any explanations?
    Graphics card is Xfx version too.
  2. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    Some running program is making the GPU work. I wouldn't worry about it.
  3. SmilerAl
    6 May 2010
    Seems you were probably right, it's gone back down into the 30's now, I was just worried something was happening to cause it to get so hot when from my view it was doing nothing.
  4. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    have a look what programs are working in the background (msconfig) disable anything you dont need and reboot, see if that helps
  5. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Theres really no need for that. Theres no issue here.
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Bit odd as the GPU usage was 0% for nearly all of it...
  7. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Something will be switching the card from 2d to 3d mode, so even though there's no GPU usage, it's still cycling 3d mode.
    Aero may be involved?
  8. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    your getting in the 30's at 22% fan speed?
    ive got the same card and im running at 44% to maintain 43 degrees right now (no load). whats your ambient?
