Windows Create ISO image from HDD
Discussion in 'Software' started by MrWillyWonka, 22 Oct 2004.
  1. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I am having some problems with my DVD-RW/CD-RW drive, what I need to do is create an ISO image of some files which are on the hard drive. I was planning to copy it onto CD, then create an ISO image from the disk. However I cant burn a disc at the mo.
    So, is there a program that will allow me to create an ISO from the HDD, not from the CD?
    thanks in advance!
  2. MrWillyWonka
    25 Jul 2004
  3. Darv
    Darv Bling!!
    12 Aug 2002
    WinIso, Isobuster etc have this feature I think but I'm not certain.
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Most CD burning software allows you to select an "image" recorder. This will save your CD project
    onto your HDD as an iso or the software's own equivalent for later burning.
  5. MrWillyWonka
    25 Jul 2004
    What I mean is that I have a bunch of files (about 580MB) on my HDD, but I wish to turn it into an ISO image, it is not on disk at the mo cos my CD-RW doesnt seem to be working properly, its on the HDD, I want a program that will allow me to turn normal stuff on the computer into an ISO, without copying onto disk.
  6. woodshop
    woodshop UnSeenly
    14 Oct 2003
    just like IanW said.
    Go to nero (or other) select the files. when you get to the select recorder option select (image) or Hard Drive and then you'll get a save as box then it'll make the image and save to disk
  7. MrWillyWonka
    25 Jul 2004
    I must have misunderstood you, after a bit of looking around nero, I found what I was looking for, thanks for your help!
  8. Tech-Daddy
    Tech-Daddy What's a Dremel?
    8 Oct 2003
    You can also usually find a freeware/shareware version of WinImage. THat will let you save to .ISO formats.
    :thumb:
