Other Creating Virtual Landscapes
Discussion in 'General' started by TheMusician, 17 Aug 2009.
  1. TheMusician
    TheMusician Audio/Tech Enthusiast/Historian
    13 Jul 2009
    Anybody know what software would be best for creating virtual landscapes, where I can create roads on bump-mapped terrain and place buildings imported from Google Sketchup?
    I'm trying to re-create the town which I live in the 1950s, virtually. I've got all the building and vehicle models I need, as well as mapping and topographic information. I just need a program that I can build it in.
    Sketchup doesn't seem very good for landscapes. Crysis's Sandbox Editor is okay, but is really catered for gaming, and isn't compatible with much.
  2. Shepps
    Shepps Slacking off since 1986..
    5 May 2002
    You could give blender a try, it's free and you can import models from a number of other 3D applications.
    http://www.blender.org/
  3. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    urgh blender.
    Get 3dsmax and the architecture model pack. Learn to model, create shaders, rig lighting scenes up and render. Be amazed.
  4. jhanlon303
    7 Sep 2006
    Fixed that for you.
    john
  5. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
  6. §§...
    §§... What's a Dremel?
    19 Mar 2003
    For easy to use 3d landscape stuff, Bryce is really easy to learn and use, and relatively cheap
    The other serious landscape specialist software you may want to check out is Vue
    For the serious general 3d stuff, Blender is of course free, but in addition to 3ds, thre's Maya Personal Learning Edition is free for learning / non-commercial use ( not sure, but there may be some rendering limitations like a watermark)
  7. kingred
    27 Mar 2008
    not if you use the "trial" version. Hell how do they expect students to learn their software otherwise, so then they go into the industry and say "oh i know xyz does it really well" then they buy 2384854 licenses making up for that loss.
  8. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I'm not sure any company really spends $2.4bn on 3D modeling programs on the whim of a single employee but I could be wrong.
  9. Nexxo
    23 Oct 2001
    Second Bryce and/or Vue. They went through a phase of relaeasing free, unlimited versions of older editions on cover CDs so you'd want to upgrade. In any case Bryce is still only £75,-- of so.
    The trickier part is to import Sketchup models. Bryce will import .DFX models and SketchUp Pro will export them --but the Pro version only offers limited trial runtime in hours.
    My fix: use Google Sketchup for design; keep copy of Sketchup Pro only for a quick launch, open Sketchup file, export in the desired format, close.
