Hardware Creative Gigaworks T20 speakers
Discussion in 'Article Discussion' started by Tim S, 15 May 2007.
  1. Mister_Tad
    27 Dec 2002
    Theres no reason why you wouldn't be able to do that, provided its from an analogue source
  2. Monkey2
    Monkey2 What's a Dremel?
    3 Oct 2003
    I currently have a 5.1 setup (logitech X-530) for gaming and music listening, but i notice that the sound isn't the best when cranked up, particularly from the subwoofer which is so annoying i have it turned down to its minimum volume. Also the cabling is a pain, particularly for the 2 rear speakers which i have to put under a rug as the wiring isn't long enough and is non-replaceable.
    Would I be really missing out with not having the centre and bass speakers? Or would it make more sense just getting a better 5.1 system?
  3. completemadness
    completemadness What's a Dremel?
    11 May 2007
    if you like 5.1 - stay 5.1
    but if not, then the creative 2.0 speakers are gonna be a good choice i don't think you would miss not having a center speaker, and the surround is a nice feature (especially in games) but its not the be all and end all
    edit:
    and a good 2.0 system is still miles better then a crappy 5.1 system, more speakers doesn't make up for crap speakers
  4. Jipa
    5 Feb 2004
    Usually when the speakers are hooked up to a PC the center speaker is useless as the front speakers are so close to each other. And also I'd say that if you don't care a **** about room acoustics and place the speakers "where they fit" it isn't worth it to ever even consider getting a surround set. The way the speakers are located makes all the difference even when not talking about hi-fi.
    In the end choosing between surround/2.0/2.1 is all about opinions and if you watch movies/play or listen to music more. If you love music then 2.0 is an excellent choise. I'm just wondering if moving to these Gigaworks is so huge improvement after the X-530 set... You might want to try and listen to them in a store or somewhere before buying.
    And about the subwoofer/bass. If the speakers are designed to be 2.0 then there SHOULD be enought bass in the speakers themselves not to miss the sub.
    IMO the best choise for you would be to keep the X-530 set and buy headphones.. Then when you watch movies or play you could use the 5.1 speakers, but when listening to music or just wanting better sound quality you could switch to headphones.
    Personally I have a decent 5.1 system with discrete parts, but I still listen my music 2.1.
  5. ralph.pickering
    ralph.pickering What's a Dremel?
    6 Apr 2005
    Elitist much? You clearly haven't looked into it too hard if you think the X-fi isn't any good. Creative may have made some rubbish cards in the past, but they have also made some very good ones, such as the AWE64 Gold back in the days, and the X-fi Elite Pro now. The X-fi uses the same DACs as are in the E-mu 1820m, and it has got some rave reviews from hi-fi and pro audio sites. Sure it isn't up there with the £1000+ pro level cards, but then it's not aimed at the same market as they are.
    The X-Fi Elite Pro in my HTPC replaced a Marantz CD transport and a £500 Monarchy Audio DAC (too much gear in the lounge according to the missus), and the X-fi certainly matches the far more expensive hi-fi equipment it replaced in my opinion. Both are playing through a 650W Nikko amp from the 70s, mid-range Van Den Hul interconnects, and a pair of Ruark Crusader floorstanding speakers. So maybe not uber-high-end, but not cheap rubbish either.
    But I will agree with you that the effects are superfluous and best avoided. Just don't throw the baby out with the bath water. The Xfi is a good card.
  6. loratio
    loratio What's a Dremel?
    23 Jul 2005
    Sounds interesting. Do you have som links for those?
    Cheers
  7. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    You don't need no more reviews! :p
  8. rupbert
    rupbert What's a Dremel?
    28 Jul 2002
    I know!, does he not realise that Bit-Tech is the final word in reviews :)
  9. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Just got a pair of these today to complete my rig.
    Super impressed, lovely warm sound, highly recommended.
  10. sniperdude
    sniperdude Minimodder
    8 Sep 2010
    thats nice but this thread is 5 years old LOL
  11. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Holy thread revival Batman.
  12. Shirty
    18 Apr 1982
    They are great though :)
    YEHBABY likes this.
  13. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Yeah T20s are pretty awesome.
  14. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
    Yes they are and I was surprised to see that they have not dropped that much in price considering the newer models that have been released since then, I upgraded to the GigaWorks T40 Series II which cost about £75, good sound for gaming with plenty of bass definitely worth a look if anyone is looking for speakers that don't take up too much room and doesn't want a sub.
  15. sniperdude
    8 Sep 2010
    I have the GigaWorks T40 s2 for my media center pc and have I to agree....They are really nice speakers.
  16. Combatus
    16 Feb 2009
    Got some recently too! £35 off amazon :D
Tags: Add Tags
