Gaming Critical Hit: The Trouble With Lightsabers
Discussion in 'Article Discussion' started by arcticstoat, 22 May 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Mentai
    Mentai What's a Dremel?
    11 Nov 2007
    I think the star wars universe is inherently flawed for MMO's because of this. I don't think a bunch of jedi running around 1 hitting everything would be fun and dulled lightsabers wouldn't be either. On the other hand, fiction like Mass Effect doesn't have any ultimate class, and actually has the backbone narratively to support excuses for balancing.
  3. Boogle
    Boogle What's a Dremel?
    8 Mar 2002
    I wish they did what you said - balanced in other ways. A Jedi could attract attention where a smuggler may not. So while a Jedi will be rewarded for hacking up a load of enemies, a smuggler can be rewarded for evading.
    Although really, if I'm totally honest - why not just have everyone as a Jedi? OK it's not uber-realistic, but it's what the fans are most likely to want to play. If the game is centred around everyone being a Jedi then it can be designed in such a way to accommodate that rather than gimping Jedi to cater for classes people can play in any other MMO. This MMO should have been brave and unique, rather than just copying all the existing conventions.
    I think flaws aside, Force Unleashed II struck a good balance of making the Lightsabers seem powerful without totally unbalancing the game. I doubt it's possible to get the same sort of mechanics working in an MMO, but I think it does show that balancing is possible even with uber force powers.
  4. StoneyMahoney
    StoneyMahoney What's a Dremel?
    10 Jul 2009
    If you can't handle an imbalance like this in-game without ruining the feeling of playing it or failing to live up to expectations, perhaps some other game mechanism could be employed in some unconventional way to balance it out.
    EG: What if the PC spods (smugglers, pilots et al.) just respawned in the usual MMORPG manner, but big-damn-hero OHK machines (Jedi, Sith) required a WoW hero class-style unlock, were restricted to one per account and suffered perma-death, a la Diablo Hardcore?
    Did the developers not watch the films? Don't they know what happens when you kill a Jedi? They couldn't have worked that into the game somehow? Or could they not figure out how to program a glowing blue outline shader effect? Your tragically killed Jedi hero recruits and trains one of your spods from beyond the grave to take over as your hero character. That actually might have made a Star Wars game cool for once!
  5. vaderag
    vaderag I know what a Dremel is...
    19 Jul 2007
    If i'm not mistaken, a Jedi has to construct his own lightsaber... why not stick a mechanic in where at lower levels, you just didn't construct you saber very well, so it keeps cutting out at certain points. That way, you can yank it out every now and then (more as the game goes on), but at other points you have to revert to your blaster etc...
  6. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    ^^ This is an excellent idea. Wish I'd thought of it first :D
    An alternative would be to make all Jedi NPCs and not a playable class - although I guess that wouldn't have been a popular move and would have elicited howls of pain from Star Wars geeks around the world.
  7. Spuzzell
    Spuzzell What's a Dremel?
    11 Mar 2010
    Lightsabers not being insta slice and dice did annoy me briefly in KOTOR, but then I realised that it was a game and got over it.
    Its not like anyone has a hissy fit over characters with guns shooting people directly in the face and just doing 2 damage.
  8. The Monk
    The Monk Minimodder
    15 Dec 2010
    Genius idea. Also the higher level you get the longer it goes without breaking, meaning there is some reward for levelling
  9. vaderag
    19 Jul 2007
    Yeah, that's what i meant by "(more as the game goes on)"... still, glad it's not just me that thinks that is the best (and only) way to realistically do it and keep both the traditionalists and the gamers happy!
  10. vdbswong
    vdbswong It's a Hedgehod
    23 Apr 2009
    Actually since this was going from a lore perspective, i believe if a lightsaber isn't constructed "very well" the thing either doesn't work or is rather dangerous (maybe it explodes) - hence why only force sensitives are required to do it.
    Maybe shoddy components or something, but poor construction wouldn't be one of the reasons. (It would be rather funny to explain it as a large batch of XXX component was found to be flawed and they haven't been able to bring out a new revision).
    Also the mechanic would have to work on a time basis, rather than by random since RNG is usually the bane of most PvP and is rather annoying.
    And on a side note, if that mechanic were implemented, how would it be regulated? For example if you implement that mechanic, i assume that you're trying to justify having Lightsabers "1 hit" people... as such, why should it matter "how long" you can use it for since combat invariably wouldn't last very long anyways.
    Anyhow.
    / +1
  11. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    It's long been true with a lot of games that reduce the effectiveness of weapons often making them completely unrealistic, guns and magic being two that come to mind. Ok, so lightsabers and magic are a fantasy based phenomena but a sense of realism goes a long way to drawing people in.
    In the films the games are based on the jedi rarely had cause to use their light sabers unless directly threatened or unless they were facing a mortal enemy. Often using them for defence or to merely remove and offending limb than to go all out and one kill everything in sight.
    Beginning with a training light saber that had no cutting edge would be another possible option. Having a Jedi in the game having to create a light saber from lower quality materials for lower levels due to cost and resources that was simply less effective versus higher level enemies and thus needing upgrades to become more potent. As they progress through the game and earn more money and gain access to better resources they could go on to create a better and more effective light saber.
    This would be balanced and also more in keeping with those who use firearms and being able to use a larger magazine for more rounds, or change those rounds to be armour piercing, etc
    The crystals used in light saber construction could even have a life span and each time the cutting edge is used, this drains or damages the crystal making it overall less effective until it eventually needs to be replaced or upgraded.
    The developers also show a lack of imagination for not creating enemies that are force resistant or who have defences that low grade light sabers do not work as effectively against.
  12. Lance
    Lance Ender of discussions.
    6 May 2010
    The other option is to reduce the power of other aspects of the jedi.
    For instance, being able to slice away lazer blasts, use the force (as it takes years of training, we can't all be Yoda), take a hit as we're not wearing armour.
    Jedi/Sith would be very potent in close combat, but remember in most of the films they're basically a steath unit.
  13. StoneyMahoney
    10 Jul 2009
    Why? Do you meet someone wearing *that* bikini later on?
    Lance likes this.
  14. IronDoc
    IronDoc What's a Dremel?
    7 Apr 2011
    Tbh Jedi/Sith are the most overpowered characters ever, bar Superman. I don't think there's really a very good way of dealing with it.
    One possible option, building on vaderag's, is if you weren't proper Jedi but were part of some small group of people who'd found a lightsabre and tried to backwards-engineer one. Also removes the issue of being blaster fire not being a threat. You could then become properly initiated as a Jedi later in your story.
    Like I said though, I don't think anything will be satisfactory really.
  15. cheeriokilla
    cheeriokilla What's a Dremel?
    18 Feb 2009
    It would've been cooler if they created a "star wars" world in which you couldnt just be born and decided "HEY! YOU KNOW WHAT? IMMA BE A JEDI"... But rather have the class very limited, and then have all these cool classes/jobs like smugglers, bounty hunters, rebel troopers, imperial troopers and it becomes more of a STAR WARS universe kinda game... If people can choose to be a Jedi as easily as being a smuggler, 95% of the people will choose to be a Jedi... Sad, but true... And then it becomes Jedi Wars, the universe filled with with douchebags with robes and lightsabers
  16. Bhuvsta
    Bhuvsta Minimodder
    1 Dec 2007
    Maybe the lightsabre could be 1-hit kill to make it 'realistic', but the jedi will have some kind of xp gain reduction. i.e. if the jedi can kill 10 enemies in the same time as another class kills one, they would only get 10% of the exp for a kill. Surely that would make the jedi uber and balanced at the same time. I don't know how that would work in pvp or group play though.
  17. vdbswong
    23 Apr 2009
    I can't tell if you're trying to be serious, or one of those that's obsessed with how SOE ruined Star Wars: Galaxies.
    Also, people always state that "Everyone will choose Jedi" but from everyone i've talked to/arranged to play with, as well as the general forum consensus, it seems fairly balanced (although it will invariably be skewed towards Jedi/Sith).
    In fact, quite a few people i know have simply stated they aren't going to be a Force Wielding class simply because they think that everyone will be one.
  18. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    I would have.
    Then again, they lost me at
    UberSithlord666 hits Dickwolf with lightsaber for 2 damage.
    UberSithlord666 hits Dickwolf with lightsaber for 3 damage.
    UberSithlord666 casts Force Lightning.
    Dickwolf dies.
    Quest status updated: 1/144 Dickwolves killed.
    I'm through with WoW already, thank you.
    Flibblebot and Ciber like this.
  19. Ciber
    Ciber Minimodder
    20 Feb 2010
    Made me laugh, ty.
  20. John_T
    John_T Minimodder
    3 Aug 2009
    I like the idea of weaker lightsabres for the lower level Jedi / Sith, upgrading their power as they grow stronger in the force / better learn to use technology / access better crystals etc. I think they could all work in the context of a game and still keep plausible to the ethos of the Star Wars universe.
    But, without having played the game, (so maybe I'm missing something) but why would characters have to start out as fully qualified Jedi / Sith in the first place?
    Why not start out as a 'Youngling' with NO lightsabre at all? Anakin joined the Jedi order as a youth and not a baby, (and Luke as a full adult) so that could easily be worked into a game storyline without breaking the feeling of the Star Wars lore.
    Be a 'Youngling' or novice trying to prove yourself up till, say, level 25, when you get promoted to the rank of 'Padawan'. Only THEN would you get your first, highly weakened, lightsabre, (as described above) - which over time gets more and more useful. You could be on the 'Jedi path' and not become a fully fledged Jedi until, say, level 50 - when you get your real kickass lightsabre - and at a level in the game where you'd expect to one-hit kill most standard stuff anyway.
    I think the point of the article, (and I agree with it) is that is doesn't take too much thought to iron out problems and remain 'believable' within the context of the universe created...
Tags: Add Tags
