Graphics Crossfire = No DVI Display?
Discussion in 'Hardware' started by strife045, 17 Jun 2006.
  1. strife045
    strife045 What's a Dremel?
    17 Jun 2006
    My ViewSonic VX922 LCD does not show a display at any time (POST to Windows) when using DVI input. It does work when the DVI is converted to VGA. The LCD works on DVI and a Samsung LCD has also been tested on DVI. Crossfire has been setup correctly and does work.
    System:
    FX-55
    A8R32-MVP Deluxe
    X1900CF
    X1900XTX
    2048 OCZ Plat 400
    4xRaptor 74GB RAID0
    Audigy 2
    Why would it only work converted to VGA? The monitor and crossfire dongle both use DVI-I; I have tried both DVI-D and DVI-A cables. Either one of those should work.
  2. ch424
    ch424 Design Warrior
    26 May 2004
    On the monitor, press the 1 button, then scroll down to Information and press 2. It should say something like:
    H.Frequency: 64.00 KHz
    V.Frequency: 60.00 Hz
    Does it?
    ch424
  3. strife045
    17 Jun 2006
    H 60.08 KHz
    V 60.14 Hz
    Pixel Clock 108.15 MHz
    The monitor menu only shows on Analog input.
    Using DVI nothing is displayed; the power button goes from green to yellow. This happens when in the BIOS or in Windows. From POST on there is no display on DVI at all.
