Hardware Crucial Ballistix Tracer Red PC-6400 4GB kit
Discussion in 'Article Discussion' started by Tim S, 17 Mar 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Sark.inc
    Sark.inc What's a Dremel?
    9 Dec 2007
    i don't see any pictures of the OCZ ????
  3. Guest-16
    Guest-16 Guest
    Sorry, I meant "linked above".
  4. naokaji
    naokaji whatever
    8 Dec 2006
    having a 2GB kit in the mix to compare performance to the 4GB ones would have been nice... anyway, nice review of a good product, shame that it doesnt oc like the legendary D9GMH / D9GMX ram though.
  5. Guest-16
    Guest-16 Guest
    There's plenty of 2GB memory reviews out there already and we've planned to do a specific "Is more memory better" review in a few weeks :)
  6. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Sounds good :thumb: Could you do a comparison using 4GB on a 32bit OS as well? That would be really great
  7. Tidy_Boy
    Tidy_Boy What's a Dremel?
    1 Apr 2003
    "4GB on a 32bit"
    That would be ok if 32bit OS could use all of it
  8. sam.g.taylor
    sam.g.taylor Apparently I'm Greg Kinnear
    15 Aug 2006
    How dare ye misspell Corsair! (Check the charts)
  9. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    agree with tidy_boy, I had problems with 4gb in winxp 32bit edition
  10. Guest-16
    Guest-16 Guest
    Nope, 64-bit only. The price difference between 32-bit and 64-bit OEM is nothing these days.
  11. TreeDude
    TreeDude What's a Dremel?
    12 May 2007
    Yes, but Vista in 64-bit takes up more memory that 32-bit. As do all your apps. In the comparisons I have read it is usually between 15% and 20% more memory usage than 32-bit. So having a 32-bit configuration for the test might be a good idea.
  12. Cupboard
    30 Jan 2007
    I know that there is little difference in price and that 32bit OSs can't use the lot. But I though it might have been an interesting comparison to do.
    Not to worry though.
  13. Zargon
    Zargon Master of the Universe
    16 Feb 2008
    Any chance you can look at 8gb in the review? I have quite a few questions regarding the advantages of 8gb vs 4gb (64bit vista).
  14. SNIPERMikeUK
    SNIPERMikeUK What's a Dremel?
    21 Feb 2006
    Well overclockers.co.uk are stocking the crucial ram reviewed here, on this week only for just £84.59 (inc. Vat)
  15. Guest-16
    Guest-16 Guest
    Nice find! When did it go this week only? I tried looking around last night but didn't find it. Admittedly I didn't look at OCUK though. We can't really take a special offer as a consistent price though, because next week it could be much more expensive?
    http://www.overclockers.co.uk/showproduct.php?prodid=MY-116-CR&groupid=701&catid=8&subcat=813
    Bargain!
    Zargon - it's planned as: 2x1GB, 4x1GB, 2x2GB, 4x2GB. That's a lot of hours testing.
  16. konsta
    konsta What's a Dremel?
    2 Jul 2005
    Just for an unscientific/interest point, I felt that putting another 2gb in my vista 64 system did give it an perceptible extra oomph...
    And given that the OS now idles on 1.8gb used...that would make sense. I assume that a fair chunk of that is superfetch, although it is still slightly incredible!
  17. konsta
    2 Jul 2005
    ---addendum for Zargon
    I have never yet managed to use the full 4gb, or even get within 200/300mb of it, regardless of how heavily I am multitasking - I just cannot imagine 8gb giving any further use.
  18. Guest-16
    Guest-16 Guest
    The 64-bit version of Vista is designed to use memory more dynamically, so if you have 8GB of memory it'll simply throw more into it to take even less weight off the need to access the hard drive and pagefile.
  19. ryanjleng
    ryanjleng ...
    15 Nov 2007
    Hate to jump on the request bandwagon, but if you have a bit of extra time can you run Vista vs Vista SP1. Just a normal 4GB bench (startup-idle and stressed) should be enough.
    Forget about it. I could do that here. :) Suspect M$ did something to the fundamental way Vista works with RAM given that they got a wacky branding case in the court and the slight delay in SP1 by a month or so. :)
    I think Vista SP1 should be out in a week or 2 to some. In April or May for most.
    Vista SP1 out tomorrow. Not in a week.
    It's has a lot to do with the way software is coded.
  20. Guest-16
    Guest-16 Guest
    Article Addendum: We got in contact with CrucialPR that corrected us that the memory chips used are in fact Micron, not Prochip. We have corrected this technicality accordingly :)
Tags: Add Tags
