Crucial Banner Ad
Discussion in 'Feedback & Suggestions' started by GreatOldOne, 9 Feb 2009.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Is very annoying. If it even senses that you may be approching the menu section headers, it pops open and obscures them. Please try and make it a little less sensitive. Ta.
  2. alastor
    alastor Minimodder
    6 Sep 2004
    Agreed, I keep clicking in it's popup when trying to get to the forums :grr:
  3. DougEdey
    5 Jul 2005
    What browsers are you guys using? I've not got any issues even at 1pixel to the actual advert...
  4. GreatOldOne
    29 Jan 2002
    Safari in OSX 10.5.5
  5. alastor
    alastor Minimodder
    6 Sep 2004
    Firefox 3.0.6 here.
  6. Vimesey
    Vimesey What's a Dremel?
    21 Jun 2008
    Had same problem dunno if the ads still around
  7. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    cough...adblockplus...cough :p
  8. Tim S
    Tim S OG
    8 Nov 2001
    That's what I've found having just tested it, but I will pass this feedback on.
  9. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I've noticed it once or twice, too. I can't remember whether it was at work or at home (IE: IE7 or Firefox 2.0.0.6), though.
  10. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    Just happened to me in work now. Using IE7, went to click the link to the forum and the box dropped for the crucial ad just as I clicked.
  11. Tim S
    Tim S OG
    8 Nov 2001
    I'm looking in IE7 now and I'm sitting over the forum link and it's not appearing. If, however, I overshoot with the mouse and touch the ad, it does expand. Are you definitely not going anywhere near the ad?
    I'm trying to recreate the problem from here. :)
  12. liratheal
    20 Nov 2005
    Typically, at home anyway, I'll be moving the cursor to the site from the right hand side, below the level of the ad (Typically I open Firefox, open the dailies, and open some stuff on the other screen, then come back as the dailies have usually loaded, of which Bit-Tech is the top of the pile). As far as I can remember, I'm usually bellow the ad line, because MPC opens closer to the taskbar, as do Thunderbird and Skype - Much lower than the uppermost advert.
    At work, if I'm scrolling, I scroll with the cursor in the bottom left - I find most of the sits I hit are less advert populated in that corner :B
  13. Blademrk
    21 Nov 2003
    The cursor was just under the OR in forums when the ad popped for me.
  14. GreatOldOne
    29 Jan 2002
    Arrragh!!! it's still doing it. Soooo Annoying.
    Like Bladmrk, I was just at the bottome of the forum tab on the nav bar. :grr:
  15. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Firefox 3.0.6
    Some of us would like to continue to support the site, so by highlighting these issues hopefully Dennis/bit-tech will take notice and correct the problem.
  16. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    It is really annoying. I keep simply moving my cursor over it and clicking the forums but it's opened and I click the advert. I'd rather not have to dodge adverts to get to the navigation.
  17. DougEdey
    5 Jul 2005
    I've seen this on other websites actually, it looks like a bug in the flash mouseover detection code that has the detection field set to the enlarged size rather then the default.
  18. murtoz
    murtoz Busy procrastinating
    9 Apr 2008
    Wholeheartedly agree with this one - very annoying. Any fold-out (or whatever it's called) add is really annoying... it is MY screen, stuff shouldn't just expand simply because I mouse over it (and if it insists on doing this, it should go back to its original space the moment my mouse leaves that!).:eyebrow:
    Same with the Empire - total war add on the top.
    Starting to seriously consider add-blockers which would be a shame as I don't want to take income away from you guys. Hrmpf.
