Storage Crucial M4 On It's Way Out??
Discussion in 'Tech Support' started by Pookie, 8 Jun 2015.
  1. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Hey Everyone
    I have been given an old M4 to do with as I please, my hopes are to get it going again but I think it has had its day?
    Before I flashed to the latest firmware it was running like a dog and wouldn't even format in Windows. But now it formats and and read and writes ok. Any idease if that SMART error can be resolved or should I just bin it?
    Cheers :thumb:
    EDIT: I contacted Crucial but the warranty has expired :(
  2. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    Unexpected. I thought old SSDs went into read only, but that suggests it's reads that are the problem.
    I don't have any advice, but how far out of warranty is it?
  3. TheMadDutchDude
    23 Aug 2013
    Try sticking it in the freezer in a few plastic bags which are sealed. Leave it in there for 24-36 hours and then let it fully warm up for a day. That might bring some life back into it. I know it works on RAM modules, so no reason why it shouldn't on SSDs. :D
    Although, the controller may be at fault here. The controller often dies far, far before the NANDs do.
  4. Pookie
    4 May 2010
    Thanks for the help guys. As instructed by Crucial I have left the drive plugged in over night without a SATA cable, this allows the built in garbage collection to run on the drive. The error in crystal is just the same but the drive is running faster again this morning.
    Here is a crystal speed test screen grab (test run on a SATA2 Port!).....
    I think I will just bung Windows on it and take my chances :)
  5. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I would run an ata secure erase on the disk. Sometimes you can get it back that way.
  6. TheMadDutchDude
    23 Aug 2013
    Ooh, very interesting. I didn't know the drive could have been run down like that.
    A secure erase should help too as Ivan said.
  7. megadelayed
    megadelayed What's a Dremel?
    18 Jul 2015
    My M4 256GB also had a problem when it suddenly didn't boot one day, leaving it with only the power plugged in while I went for a shower seems to have brought it back to life and still running today. But I didn't have the SMART warnings like you though.
  8. Pookie
    4 May 2010
    In the end I just ended up using it for Steam. Windows did keep popping up warning me there was a problem with the drive, but I just selected to ignore and never remind me.
    But Steam runs great from it! and if the drive dies then so be it :)
