News Crucial M500 SSDs made official, available today
Discussion in 'Article Discussion' started by Meanmotion, 9 Apr 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    A bit on the slow side compared to the 840's but some nice features included.
  3. Harlequin
    Harlequin Modder
    4 Jun 2004
    looks like they binned the V4 as well (its gone from crucial shop)
  4. Blackshark
    Blackshark What's a Dremel?
    13 Apr 2004
    1TB of Crucial SSD goodness for less than 500 GBP!! I can remember buying a 256 C300 for that price, a 512 M4 for that price. OK OK, maybe not the full TB but still that is pretty good going. So have we reached the point where development, both speed and capacity growth will slow?
  5. roundyz
    roundyz What's a Dremel?
    16 Jan 2002
    £315.99 for the 960GB would be a winner.
  6. theshadow2001
    3 May 2012
    When it comes to capacity and value on SSD crucial have it down
  7. Gradius
    Gradius IT Consultant
    3 Feb 2009
    Still capped @ 500MB/s? Too slow if you are already used to it (not me, I'm used to 2GB/s).
  8. Guest-23315
    Guest-23315 Guest
    a 960Gb drive is $600 in the US.. that would make it very attractive if the price had been ported over properly :/
  9. andrew8200m
    andrew8200m Modder
    4 May 2009
    It has... You forgot to add state tax orin the UK ... VAT.
    That makes it £473ish.. which most are at £499.99inc or there abouts.
  10. Harlequin
    Harlequin Modder
    4 Jun 2004
    nah only scan are £500 - most are less
    edit:
    I stand corrected , looks like ocuk et all are price gouging as yesterday they were £460 or so and are now £500
  11. Blackshark
    13 Apr 2004
    I am at work, but I havent found a way to squeeze a PCI express SSD in to my laptop - which is all I have at home :-( Also I am not sure what game I could run that would find much of a difference between two raided M4s in my sony laptop and a 2Gb / s PCI Express SSD. There are few games if any that run at queue depths high enough to utilise your card. Or are you using a larger array on SATA ports?
  12. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    The write speed on the 120GB flavour looks a tad slow, other current and previous gen SSDs at 120gb shown on Scans website include uppers of 300~400mb/s write speeds or is that just the speed they state on all of them?
  13. Kodongo
    Kodongo What's a Dremel?
    29 Feb 2012
    ^ It's because the Crucial M500s are using NAND which is twice the density of all the other drives therefore we have the performance of a 60/64 GB drive but with twice the capacity. This is also why Crucial refrained from releasing a 60GB version as it would be truly pedestrian compared to other SSDs.
  14. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Meh, the Samsung 840 is cheaper and the 840 Pro only costs a small premium. The M500 would be awesome if Samsung didn't exist.
    It's also worth noting the 840 series have a cashback offer until the end of May:
  15. jrs77
    jrs77 Modder
    17 Feb 2006
  16. Harlequin
    Harlequin Modder
    4 Jun 2004
    3 warranty is poor to be honest as well
Tags: Add Tags
