Hardware Crucial RealSSD C300 64GB SSD Review
Discussion in 'Article Discussion' started by Sifter3000, 21 Jul 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    delivered the performance i was hoping for, this could well be my first SSD but still think that the price is a little high
    dont have much need for high write speeds tbh for my intended use of th drive
  3. Andre_B
    Andre_B Minimodder
    17 May 2009
    Is the Bit-Tech recommended award on the last page suppose to say: Crucial C300 256GB?
  4. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    So, this seems perfect as a boot drive to hold Windows, Office, browsers and the like. Everything else can sit on a Spinpoint F3.
    I'll probably get one this week, but would appreciate advice on installing Windows (7x64) onto the drive - is it true that you should install fresh Windows onto a clean HDD and then ghost the image across onto the SSD or I am safe to perform a standard Windows install directly onto the SSD?
    Many thanks,
    Cleggy.
  5. Baz
    Baz I work for Corsair
    13 Jan 2005
    Direct install is fine.
  6. Baz
    13 Jan 2005
    thanks for the spot - fixed
  7. kenco_uk
    28 Nov 2003
    You're good to go straight off the bat, no ghosting required. I think you still have to perform alignment when installing XP, but 7 waves a magic wand so you don't have to faff about doing that.
  8. mi1ez
    mi1ez Modder
    11 Jun 2009
    I think this could be my next PC purchase!
  9. smc8788
    smc8788 Multimodder
    23 Apr 2009
    This is exactly my setup as of last weekend, and it's working well so far :)
    The only thing I can't really put on there is games, but then if I wanted to do that I would need to spend £500+ on a 256GB SSD with similar performance, since the vast majority of my games are now on Steam, and AFAIK you can't split a Steam install and games across multiple drives - they all need to be on the same one, so swapping them across isn't an option for me.
  10. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    i Love the diea of this drive especially as i have 2 sata 3 ports. but i have noticed that corsair have released 40gb, 60gb and 80gb versions of the F100 SSD and they have the same SandForce controller as the existing models. I wonder how these would stack up against C300.
    The C300 has a faster read speed (if your port can provide it) but the corsair ones have a better write and random 4k write proformance.
    Its a shame that there isnt just one drive that is the best like the F3 to makes things simpler!
  11. WarMadMax
    WarMadMax What's a Dremel?
    12 Dec 2006
    relatively simple fix,
    Easiest on Windows 7 / vista, but dooable on XP is make an NTFS junction,
    what that intails is install it as normal on your HDD ( D:\ ?) ...
    you then move the contents of the install folder into a new folder onto your SSD (should be a sub folder in steamapps ? can't get at the details, at work!)
    once you've done that, There's an app out there called junction magic that i used to create a junction point.
    junction points make read and writes that look at "D:\Steam\SteamApps\HL2\" actually go to "C:\Games\HL2"
    Because it's at file system level, the program doesn't see any of this, you can even do it on windows folders.
    As soon as the junction's active, the files "appear" at the old location in windows explorer.
    so far i've junctioned my user profile & temp drive off the SSD onto the Hard drive so that gets write thrashes, and junctioned a couple of games off the HDD to the SSD for faster loading.
    Grimloon likes this.
  12. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    i wont be considering ssd until they have much higher capacities, and prices fall inline with hard drives
  13. Grimloon
    Grimloon What's a Dremel?
    4 Sep 2008
    Excellent, I just ordered one :D I might even be able to fit about 20 GB of my Steam folder on there as well by junctioning it. Thanks for that tip WarMadMax, have some rep!:thumb:
  14. WarMadMax
    12 Dec 2006
    Just Ordered one of the highpoint controllers for my maximus formula, shall see what sata 6Gb/s brings over Sata 3Gb/s :)
  15. John_T
    John_T Minimodder
    3 Aug 2009
    This is exactly the sort of review I've been waiting to read - excellent, thank you.
  16. Makaveli
    Makaveli What's a Dremel?
    25 Nov 2009
    You will be waiting a very long time.
  17. Gannu
    Gannu What's a Dremel?
    22 Jul 2010
    The line beneath the second photo reads - 'The 64GB model uses the same 128GB cache as the 256GB version too. Click to enlarge'
    Please correct it to 128MB cache. :p
  18. Arkanrais
    Arkanrais What's a Dremel?
    14 Jul 2007
    Am I the only one wodering how 4 of these with a decent SATA-6Gbs raid card would perform?
  19. Redkachina
    Redkachina Califragilistsic Expialidocious
    2 Apr 2009
    Nope you're not the only one lol
  20. gcwebbyuk
    gcwebbyuk Dib Dabbler
    16 Feb 2010
    Am considering putting my 80GB Intel (M) drive into my laptop, and then getting two of these in a RAID array on my Marvel 6gbps motherboard controller.... hmmmm will have to talk to the boss ie wife!
Tags: Add Tags
