Reviews Cryorig Taku Review
Discussion in 'Article Discussion' started by bit-tech, 23 May 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. David
    7 Apr 2009
    I like it. The price stings a fair bit, but I like it.
  3. DanielW
    DanielW What's a Dremel?
    24 May 2018
    Thanks for the review. I've been thinking about a build with this case - it's cool, different, and, in some ways, practical. It's good to hear what some of the limitations might be.
    One question I have is that, based on the dimensions, this is a 25 liter case which is not that small. Do those somehow include the depth of the legs or something like that? The descriptions of the cramped spaces make it sounds more like a 10 liter case.
  4. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Cool, I'd love to see some builds in it. The dimensions do indeed include the legs; remember CPU cooler height is limited to 48mm so that gives you a rough idea of the real height of the actual drawer.
  5. Zak33
    Zak33 Staff Lover of bit-tech Administrator
    12 Jun 2017
    this is one of the hardware reviews that drew lots of staff in to see it.
    I find it utterly beautiful. In the steel, it's even nicer than in photo's.
    I did accidentally ping the draw open.... Dogbert had to hide the drill, as I was all over it with thoughts of a grub screw to hold it in place ;-)
  6. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    The volume includes the legs as they are nonremovable, but even if you cut them off the case itself is about 70mm thick (total volume a bit over 12L). It's not as compact as similar cases with the same component compatibility and layout (e.g. Zaber Sentry, 7L) because they have the PSU directly facing the rear of the case, rather than occupying the empty space in front of the motherboard and using an internal power cable to connect it to the rear.
  7. Dogbert666
    17 Jan 2010
    Update 28/05/2018: Cryorig has been in touch to state that it is working on a USB 3.1 upgrade kit for the Taku, although exact details and a release date are still to be confirmed.
    Corky42 likes this.
  8. Sn3akr
    Sn3akr What's a Dremel?
    26 Feb 2011
    I would love to see some custom water crammed into this :D
  9. Zak33
    12 Jun 2017
    I could spill tea into it....would that be OK?
    seriously though.. I think air cooled suits this. Water cooling it needeth not I'd humbly suggest
  10. Dogbert666
    17 Jan 2010
    It's not about need!
Tags: Add Tags
