Hey was wondering if anyone knew how to fix an issue I'm having with a Crysis install. I just built a new comp and every time I try to install crysis I get a 1335 error. It says an object file is corrupt. It installs fine on my other comp (vista), and it worked on two other friends computers (vista and xp). So I know its not the disk that's doing this? Any suggestions on what to try here? Thanks new comp specs- GIGABYTE GA-X38-DQ6 Q6600 8800gt 4 gigs of dominator ram
Same problem I have the same problem as you. I found somewhere to remove 2gb of RAM and than to try but nothing. Please if somebody know the answer help us.
Google is your friend found that in a couple of mins litterally! http://consumer.installshield.com/kb.asp?id=q110742 go there and follow the instructions, problem solved!
I fixed the problem. I reinstalled vista and it installed perfectly. So I guess im still unsure about what has changed but it fixed my problem.
Crysis Object~.cab install error I had overclock ram on a ASUS PN32E-SLI PLUS mobo with a e6850. I disabled the overclock and game installed fine
