Windows Crysis 2, SLI and other stuff
Discussion in 'Gaming' started by Pete J, 25 Mar 2011.
  1. Deders
    Deders Modder
    14 Nov 2010
    I think the console was enabled via the first patch
  2. sausages
    sausages What's a Dremel?
    20 Nov 2010
    Because there wasn't a console on release. They released a patch today (PC version only) to bring it back, along with a bunch of other things because people were going ape.
    # Server Browser shows incorrect pings - Fixed
    # Some matches never initiate - Fixed
    # Faster text chat - As speedy as can be
    # Console re-enabled - Console has been re-activated
    # Cheat detection - Now in place to ensure all users are on a level playing field
    # Fix USB headset issues – Current issues have been addressed and fixed
    # Fix hologram icon staying on screen after being used - Fixed
    # Remove Auto Aim
    The patch will automatically download when you boot the game up.
  3. sausages
    20 Nov 2010
  4. soviet_
    soviet_ Bantros
    17 Dec 2008
    Oh right, I had it pre loaded on Steam so it must've already been patched for UK release
  5. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    installed today,
    Hmmm, only playing single player, but mouse very sticky and laggy, i guess due to lots happening on screen?
    Disabled firewall etc etc, not that playable for me on my i7930 and 5870, maybe i will try reducing quality, however frame rate was ok, not sure whats going on, any ideas for me?
    Oh, and had that grey vertical lines crash, which was annoying aswell.
    Maybe i should stick to msn and forums, im good at them.
  6. Deders
    Deders Modder
    14 Nov 2010
    Latest graphics drivers? Clean your mouse?
    I'm having no difficulty playing it on my sig, what's your entire spec?
  7. PabloFunky
    19 Sep 2010
    I think i may of moved my case around too much
    ive got a wireless mouse, and i think it was too far from transmitter, or interfering with something, ive moved it and its now very playable, thanks though, guess i should try a few things before asking in future.
    However it doesent make me very good at gaming though :D.
    Spec is i7 930
    ud9 mobo
    c300 ssds
    6g of corsair ram
    single 5870
    dell 24010 old one
  8. Guest-44432
    Guest-44432 Guest
    The console is still restricted to only 47 commands. Now go and type r_displayinfo=1 in the console...did it come up with invalid command? bet it did. Now go and type that command into a .CFG file and then load the game and open the console. Notice how the console has now excepted it? But yet it still doesn't show the info...this is because they have restricted the console.
    My point is, they should of just left it alone so. This game is MAXIMUM CONSOLE.
    Simon.
  9. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    Or perhaps not...:D
    But yeah, it is not brilliant. I cannot play it yet with the 5970 as the light sources flicker really badly, and I don't want it ruining the game. I'm not sure whether adding the multi GPU command will help, will try later, but if not, I hope AMD or Crytek pull their fingers out in getting it sorted.
    From what I could see, it looked pretty good, and I enjoyed the demo.
  10. theskirrid
    theskirrid What's a Dremel?
    15 Dec 2009
    Marvin -
    On Steam: you can either play windowed, or force a decent [Bioshock usually]Xfire profile using the RadeonPro tool. You'll also need Catalyst 11.4preview and 11.2Cap4 Profiles.
    On Retail just rename Crysis2.exe to Bioshock.exe.
    And it doesn't always work.
  11. sausages
    20 Nov 2010
    practice makes perfect :)
  12. GavX
    GavX What's a Dremel?
    5 Apr 2008
    Well I got my copy yesterday, didn't get a damn chance to play it, so I have specifically got up early on my day off to play it :D Not had my gaming machine on for 3 months, got an SSD and GTX570 so hopefully this will give it a wee warm up (before Arma II..)
    Damn slow DVD drive, sure this is my bottleneck now
  13. Panomama
    Panomama I once signed up on uniform dating
    11 Jul 2009
    I'm on the 3rd level of it on xbox360 (yes I know, my rig is a 9800gtx with AMD x2 6000+ so I would not be able to play it :/ ) and I am loving it so far. I thought that the city enviorment would put me off, but it looks amazing.
  14. soviet_
    soviet_ Bantros
    17 Dec 2008
  15. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    THIS is a tool that creates the autoexec.cfg for you. You can set details and vsync etc and your AA. Not too bad i say.
  16. GavX
    5 Apr 2008
    Urgh, Crysis 2 suffers from the same issue I had with Crysis 1, in that I can't seem to kill any body with a rifle from more than 1meter away! I can only assume its a health regenator thing the baddies get, cause I shot one guy about 7 times in the face and he didn't die! :(
  17. Jedra
    Jedra Supermodel
    11 Sep 2010
    OK, my will power dissolved and I bought it! Problem is that even with the 11.4 preview drivers and the RadeonPro profiles set, I am still getting the 'flashing lights' problem. Playing in window mode stops this but kills my fps!
    I think I will have to wait for a driver update to play this properly.
    *Edit* I don't know why they want my suit - their armour seems much better than mine!!
    Also - Wot! No quicksave?!?!?!?! I hate checkpoint games!
  18. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    FYI ive heard on semi decent authority that the DX11 patch lands tomorrow.
  19. Nealieboyee
    14 Aug 2009
    I'd like to hear your opinion on the game Gunsmith....
  20. sausages
    20 Nov 2010
    Call of Crysis
