Windows Crysis capable
Discussion in 'Gaming' started by darkvirus999, 13 Apr 2008.
  1. darkvirus999
    darkvirus999 beware of hackers
    21 Jul 2007
    Hey im building a new pc at the moment with a Q6600 CPU, 2 Gb DDR2 and a(for a start untill i have the money for better) nvidia 9600 GT Overclocked edition
    I was wondering what kind of performance will i get from cysis on this rig considering that i have a 22" widescreen monitor and am planning to play the game at 1680 x 1050
    Has any one benchmarked this game on a similar computer spec, if so could they PM me with the results please.
  2. Fishlock
    Fishlock .o0o.
    22 Nov 2004
  3. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Definitely get a 4Gb kit if you can.
  4. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    I have 2gb of ram, q6600, x1950 pro.
    I play with mostly medium settings and some on high at 1280x1024. It runs pretty smooth, so with the 9600gt it will run fine at the slightly higher resolution.
    if you do get 4gb of ram like the other guys suggested, get 2 2gb sticks and not 4 1gb.
    and make sure that you have a 64bit os to take advantage of the full amount of ram. Although I dont think you need it to be honest. 2gb works fine.
  5. atanum141
    22 Jul 2004
    I seriously doubt it will play at native rez with everything set to high. Maybe at a lower rez.
  6. kno3
    kno3 What's a Dremel?
    29 Mar 2008
    Yes, absolutely not! I have a Q6600, slightly overclocked, 4GB Corsair Dominator, 2x 7900GT (overclocked) and I find it hard to get into many of the high settings without it slowing to the point where it is difficult to play, when there are multiple enemies around you. It is a seriously power demanding game! If you don't have a lot of money to spend, just forget about trying to get the amazing graphics you see in the screen shots, it just wont happen!
    EDIT: Just reread you post, I thought you were getting a different graphics card on first read, yeh, with a 9600 you will probably be able to do it! If you run vista 64, then try to get 4GB of ram, it will make a difference! Less so if you don't want to go 64.
  7. cogitoergosum
    cogitoergosum What's a Dremel?
    14 Jul 2004
    I would suggest avoiding Vista64 and try XP64 first to save some resources.
    With the rig that is in my Sig and my 8800GTS 640mb SLI I can run at "high" settings at 1680x1050, but the second I hit some action it slows down a bunch.
  8. kenco_uk
    28 Nov 2003
    You might save resources using XP64, but it's effectively crippled by not being broadly supported by third party drivers.
  9. kno3
    29 Mar 2008
    Agreed. Id go for vista 64, you can get DX10 on it!
  10. toy_soldier
    toy_soldier modder
    21 Apr 2008
    I have 2 gig of ram. a core 2 duo e6300 an an geforce 8500gt and i can play the game with most settings on medium and a few settings on high. whit an resolution of 1024x700
  11. oasked
    24 Aug 2005
    That's mostly because the 8500GT just is nowhere near powerful enough for a game as demanding as Crysis. To play Crysis smoothly (at medium/high) with DX10 you need a 8800GT MINIMUM. :)
  12. MontanaFX
    MontanaFX Sent from the skies
    23 Apr 2008
    It should be capable of running it at medium setting with out any problems. I am not sure if adding another 2gb of RAM will effect it that much. It should be OK as is.
  13. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I very much doubt an 8500GT will be able to run Crysis at medium settings... certainly not at anything like acceptable frame rates :idea:
  14. MontanaFX
    23 Apr 2008
    I agree, but he has/is getting a 9600 OC.
  15. toy_soldier
    toy_soldier modder
    21 Apr 2008
    here are the settings i play crysis on with my e6300 and my geforce 8500gt.
    texture quality high
    objects quality medium
    shadows quality medium
    psysics quality medium
    volumetrics medium
    game effects high
    postprosessing medium
    particles medium
    water medium
    sound high
    I have made a little fraps movie and upload it on youtube, so you can see how i play it. here is the link: http://www.youtube.com/watch?v=4lHDiouFWWI
    bye,
    toy_soldier
  16. Tsen
    Tsen Steeped In Romance
    29 Apr 2006
    I get pretty great framerates on medium and playable on high with an 8800 GT with an otherwise similar setup. The 9600 is slightly less powerful, but you'll definitely be able to play on medium, and possibly on high (though you'll see some choppiness when enemies are around on high). I can even squeeze by on very high, but only if there's nobody around.
  17. toy_soldier
    toy_soldier modder
    21 Apr 2008
    i'm riunning the game with a resolution from 1024x700 that is low but my screen is 17" so it lookt great on my screen. I think that it is not playable when I try to play in a higher resolution. And btw i'm running on windows xp. I have try it in Vista and then I must set all settings in low.
  18. MontanaFX
    23 Apr 2008
    I play @ reso 1360x764 with a 8600gt on medium with no problems.
  19. kenco_uk
    28 Nov 2003
    8800GTS 640MB, some medium, some high, 1920x1200, plays smoothly enough.
    Haven't tried my new 9800GTX yet :naughty:
  20. 12modderz
    12modderz L33T еÐ3!
    29 May 2007
    The game runs okay on my 9800xt 256mb @ 1280x1024 with everything on low.
