News Crysis Minimum Requirements Revealed
Discussion in 'Article Discussion' started by CardJoe, 10 Oct 2007.
  1. Rebourne
    Rebourne What's a Dremel?
    26 Jul 2007
    I played with minimum specs and an 6800 gt for the beta and found it to be playable and smooth with things on low and a few on medium. It didn't stutter and wasn't buggy to the point it wasn't fun to play so I think people will be fine.
  2. GoodBytes
    20 Jan 2007
    You guys mention for recommanded "Intel Core 2 Duo 2.2Ghz" But it's also mentioned on their website and several other sourcese the: "Intel Core 2 Duo 2.2Ghz \ AMD Athlon 64 X2 4400+"
    Don't discriminate AMD users!!! :(
  3. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Rofl, as if a 4400+ is equal in performance to a C2D at 2.2 - and yeah, hopefully optimal will = able to do 14x9...
  4. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    /me hugs his GTX's
    i knew it was worth the extra money :D
  5. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Hrm, looks like anyone who wants to run it in Vista will need to overclock, or downgrade to a P4.
    Why is it that game companies still put things in Ghz? It's not like they're any indication of performance any more.
  6. Vash-HT
    Vash-HT What's a Dremel?
    7 Jun 2006
    Well,
    GHz indicates the same thing it always has, its not like it used to represent performance and now it doesn't. The problem is when they lay out a generalized clock speed without specifying a processor, because the clock speed only indicates performance relative to processor in the same family. Its weird that the minimum calls for 2.8GHz at the lowest, but the recommended calls for a C2D at 2.2GHz lol. They should really stay consistent with their identification schemes.
  7. GoodBytes
    20 Jan 2007
    @Tulatin:
    For Today's games the CPU won't give you much. It's the video card that does the major part of the work. Having a faster CPU will increase your speed but what? 10-15%, nothing major.
    So the AMD Athlon 64 4400+ is correct in the specs.
  8. crayfish
    crayfish Amazing scenes!
    3 Dec 2002
    I bought my new PC back in March with Stalker in mind but it still just squeaks over the recommended spec :D
    E6600 2.4GHz
    2GB RAM
    Single 8800GTX
    I wonder if my native of 1680x1050 will be possible with all the bells and whistles on.
  9. heir flick
    heir flick Minimodder
    2 Feb 2007
    still trying to find out if it will be optimized for quad cores, read rumors that it will be but no real information yet
  10. bahgger
    bahgger Minimodder
    13 Apr 2005
    Quad cores, maybe. Dual cores, I sure hope so! There's bound to be far more market penetration with dual cores than quad cores at the moment if I'm not mistaken
  11. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i was expecting more.....
  12. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Was it not said that Crysis performed best under Direct X 10, 64bit, multi core?!
    QFT!!, ughh so true!! Then again I guess this is also where Vista's performance index comes in, and games im sure we shall soon see stating it requires a minimum rating of say 3.5 etc.
  13. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    as soon as my graphics card comes in, Im good to go ^_^
  14. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    I'm quite set for Crysis so it seems, can't wait to give the full game a try. Hopefully it takes less system power then the beta of it does, because that makes me play on mid/low settings if I go for native resolution of my monitor(1280x1024). Although I only had 1GB of ram installed at that point, so it may run higher when I have a full 2GB again.
  15. Mister_Tad
    27 Dec 2002
    Half of me was worried that little over a month after upgrading, crysis would need another upgrade.
    Though that doesn't give any indication of resolutions, fingers crossed. This game is going to determine whether I get a 24" or not :blush:
  16. completemadness
    completemadness What's a Dremel?
    11 May 2007
    I think the beta will probably get quite a bit better in terms of performance
    ATM the code does seem to bog it down a lot, and if you look in the console there is a tonne of useless logging
  17. ezee
    ezee What's a Dremel?
    14 Jan 2009
    I have 1.86 GHz pro
    2.5 GB Ram
    and 8400 GS Video card
    What are the recommendatons for me regarding this game?
  18. ezee
    14 Jan 2009
    Actually Core 2 Duo 1.86 GHz pro
Tags: Add Tags
