Gaming Crysis Multiplayer Beta Impressions
Discussion in 'Article Discussion' started by Tim S, 25 Sep 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. 1e8o
    1e8o What's a Dremel?
    13 Oct 2005
    I really want this game :p top of the notch
  3. wyx087
    15 Aug 2007
    wow, superb graphics. is game is one of THE reason i built my new computer, im sure many other people are the same.
    wow. i thought they said the game can be played at 1280x1024 with a 8800GTS :(
    what sort of framerates are you getting with your 640MB GTS? and are settings maxed out playable?
  4. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    It was stated quite clearly in the article that this is a beta and the graphic performance has not been optimised yet.
  5. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    Well, it's a beta so it isn't optimised code or indicative of final code at all. But, as it was, with the 640 GTS it was ussually around 10 FPS with everything on High (VERY high is greyed out). With the ultra is was more like 12-15 FPS on those settings.
    I actually dropped to medium and low in order to get the feel of the game, reserving the high settings for the wow factor and screenshots.
  6. Guest-16
    Guest-16 Guest
    It was stressed that this is a beta so there's a LOT of optimisation still to come. I would be greatly surprised if an 8800GTS won't be able to play it on high at 12x10 come final release. :)
    M-M-M-M-MULTI POST on the same subject
  7. tuteja1986
    tuteja1986 What's a Dremel?
    25 Sep 2005
  8. Henk
    Henk Uninformed Opinionist
    16 Jul 2006
    So, how did it use the cores on your cpu? Did you run it with a dualcore or a quadcore?
  9. CardJoe
    3 Apr 2007
    dual, I believe. It's just more representative of most gamers.
  10. carlogiovanni
    carlogiovanni What's a Dremel?
    25 Sep 2007
    You are breaking the NDA.
  11. xrob
    xrob What's a Dremel?
    31 Dec 2005
    i wish you'd take some nicer screenshots! whats with those insanely badly compressed jpegs. looks sick even with them though, i want this game so bad
  12. CardJoe
    3 Apr 2007
    Bit-tech has signed no NDA and the Terms and Conditions don't explicitly mention an embargo of any type. However, it appears there are timing problems between EA and ourself and in order to ensure that we can continue to work closely with EA's UK PR team, we will be removing the story until tomorrow morning.
    Sorry for all the confusion and replacement content should be up shortly to keep you all entertained. This article will be going live again early tomorrow morning as part of an agreement with EA.
  13. Panos
    Panos Minimodder
    18 Oct 2006
    The test was under XP using DX9 or under Vista and DX10?
  14. CardJoe
    3 Apr 2007
    While you'll now have to wait until tomorrow to read it, the test was done using Vista but the beta only allows DX9. DX10 option is not enabled.
  15. Kurayamino
    Kurayamino As long as the Raven flies
    5 Sep 2005
    What a tease! :p
  16. DeXtmL
    DeXtmL What's a Dremel?
    7 Sep 2007
    Which time-zone are you in?
    I mean, when is tomorrow morning ?
  17. Tim S
    Tim S OG
    8 Nov 2001
  18. wyx087
    15 Aug 2007
    sorry. i know it's been said many times, but i still wanted to know what kind of performance one would get for Beta. so i can set myself a rough target of what to expect.
  19. capnPedro
    11 Apr 2007
    Arhhhh I missed it!
  20. evox
    evox What's a Dremel?
    19 Jul 2007
    It's not a valid NDA unless it's signed and stamped. this so called "NDA" is a joke. go crazy:
    http://www.nvnews.net/vbulletin/showthread.php?t=98166&page=10
    the performance of the BETA is pretty bad. okay, it's really bad, it gives sub 30 frame rates with 8800GTX@720p
    after Crytek delayed the Demo, they pretty much lost my interest. there's only so long one is willing to run for a game :/
Tags: Add Tags
