News CryTek specs a budget machine for Crysis
Discussion in 'Article Discussion' started by CardJoe, 17 Jan 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. aau03105
    aau03105 What's a Dremel?
    26 Jun 2007
    Q6600 @ 3.2Ghz
    EVGA 8800 Ultra Superclocked
    2 gigs of Corsair 8500C5D @ 1068Mhz
    At 1920x1200 I was getting an average of 25fps on high settings.
  3. mutznutz
    mutznutz Cos Ive got a beard u label me evil
    18 Nov 2007
    Those specs are better for me then I thought they'd be
    Once I get the new graphics card I'm pretty much there (Overclock the nuts off my 6300 mind :))
  4. lewchenko
    lewchenko Minimodder
    17 Dec 2007
    This story is missing some key vital information :
    1. What resolution and other graphics settings would this 'crysis approved' machine spec allow you to play HIGH detail on ?
    2. How many FPS would that give you ?
    3. Whats the typical cost of such a machine ?
    I personally dont mind.. my machine is above and beyond the spec and plays the game fine... but people who complain that their uber PC can only get 25FPS at such a high resolution of 1920x1200 need to be more realistic. At that resolution.. your PC is average. For you Sir.. perhaps I would recommend a stonking new QX9770 coupled with 2 8800 Ultras.
    Or alternatively... lower your resolution a little.
  5. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    That windows XP part is interesting.... it means i cant get any DX 10 stuff.......
  6. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    At my fairly low res of 1440x900 i can play it on high, averaging about 30fps, it drops off a bit in places but i've only played the demo and the benchmark.
    A lowly 939 a64 4600 (?) with a slight overclock, 2gb low latency ram and a 320mb 8800gts.
  7. Aankhen
    Aankhen What's a Dremel?
    15 Oct 2005
    I'm guessing the "High" setting doesn't include a preset resolution. Not much use having great effects if you're running at 640×480… by leaving out the resolution, they've essentially made this list worthless.
  8. Tim S
    Tim S OG
    8 Nov 2001
    1. I've just added that into the story - 1280x720.
    2. It's stated as "smooth gameplay"... so probably 30fps.
    3. The price can be found by just pricing up the components in the bit-tech shopping engine.
  9. Orionche
    Orionche Guest
    Beside the graphics/physics, Crysis is mediocre at best. Buying a whole new computer cuz of a game that most people won't play more than 2-3 times seems illogical. To me, anyway. :)
  10. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    Well the standard benchmark for modern games resolution is 1280x1024, so I'd imagine it'd be somewhere around there. Personally, I'd say my 1440x900 resolution is good enough with some AA, and I highly doubt they'd suggest a machine that could only run in 640x480 (is that even an option?). By the way, the Kotaku site lists the machine as $900, so maybe around £600 over here?
  11. Glider
    Glider /dev/null
    2 Aug 2005
    Budget and gaming in the same sentence... Isn't that a contradiction? It's like buying a cheap server...
  12. steveo_mcg
    26 May 2005
    True but for many people a new testing game is the catalyst they've been looking for to justify some new shiny kit. Whilst Crysis may not be all that in the next few months all games will start taxing your poor old computer, so you might as well upgrade for this as any other game. One might only play Crysis once but its not like the computer will go in the bin after you're finished with it.
  13. aau03105
    26 Jun 2007
    Who's complaining? I played at 25fps and loved every minute of it. I played around with the settings ALOT and found that full 1920x1200 resolution was by far the best gaming experience. It looks awsome, removes all the jaggyness from the trees, and most of all makes you feel like you're playing something a little bit special!
    Sir
  14. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    that system is better than mine, only slightly though and mine played the game well imo. I only have more ram, as you can see in my tag.
    peace
  15. Xir
    Xir Modder
    26 Apr 2006
    Maybe it should be considered in tests that most people don't have a 1920x1200 resolution. ;)
    Standart 19" is 1280x1024.
    Standart widescreen is what? 1440 x 900 (19") or 1680 x 1050 (22")?
    These smaller Resolutions could well be included.
  16. cjoyce1980
    cjoyce1980 What's a Dremel?
    17 Jul 2007
    budget machine that cost £700+, no wonder users are not buying crysis.
    also there budget machine out specs there recommended machine.......:(
  17. fargo
    fargo What's a Dremel?
    13 Feb 2006
    I don't understand why you need c2d to run crysis, with my old box at 1280x1024 on medium
    settings I averaged 30fps according to fraps and the game looked sweet with no lag. what more
    could I ask for with my rig!
    intel p4 3.2
    2 gigs ram
    ati 1950 pro
  18. steveo_mcg
    26 May 2005
    Because they (or ea) got paid a lot of money to advertise C2D in there shiny new game.
  19. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    Crysis is to scale ahead 2 years. That means that even current high end hardware is at about 50% with the game. Hence why everyone and there brother has not even come close to the high settings without any lag. Wait till our graphics cards are pushing 256+ stream processors and watch as Crysis sings!
  20. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    why is crysis to scale ahead two years? the game is out now, people want to play it now. in two years, we will be playing new games.
Tags: Add Tags
