Windows CS/Steam
Discussion in 'Gaming' started by Carlk, 15 Jul 2004.
  1. Carlk
    Carlk What's a Dremel?
    10 May 2004
    anyone know if CS works with Linux? im board of windows and thinking of going linux
    thanks
  2. Morphine
    Morphine weeee!
    23 Feb 2002
    youll need to setup WineX.
    I''m not sure how well it works though as I have never tried it and I dont have linux on any of of my systems rght now. It was on my laptop till it caught fire :worried: might be a sign from Billy Bob Gates not to dual boot his OS with another.
  3. sheardjr
    sheardjr Minimodder
    7 May 2003
  4. Carlk
    10 May 2004
    Ahhhh :miffed: , any patches out there 2 fix it?
  5. Morphine
    Morphine weeee!
    23 Feb 2002
    to tell ya the truth your pretty screwed for linux use of any HL game. they are taking down the WON server VERY shortly, so steam is mandatory. I don't even run my HL game servers in linux anymore as the linux version of the steam and HLDS suck compared to the Windows one.
  6. Carlk
    10 May 2004
    Oooooh :sigh: , looks like im stuck with windows then.
    dammmmmm
    what OS are you running then?
  7. Morphine
    Morphine weeee!
    23 Feb 2002
    meh, jsut dual boot a smaller copy of windows. like perhaps a stripped down windows 98 or 2000. should hog much space on your hard drive and will let ya get the best of both worlds
  8. Carlk
    10 May 2004
    lol, y didnt i think of that!!? yeah good idea
    thanks alot man :thumb:
  9. Morphine
    Morphine weeee!
    23 Feb 2002
    I know when I installed redhat 9 it even installs a boot loader program-thinger that lets you choose between multiple OSes. Might be usefull If you partition off a section of the HDD for each OS to keep them seperate. Mka e sure to make the windows partition FAT32 if you want the linux partition to be able to read it. I think the boot loader program might auto detect the windows install if its alreay setup before the linux install, that would make it easier to set it all up. I wouldnt know though, I installed redhat on my laptop and did have a windows install to dual boot with at the time.
  10. Carlk
    10 May 2004
    i got 2 hard drives, 1SATA for windows and one IDE for linux ( 50%50). wll the IDE b ok 2 use?
