Development CSS Help!
Discussion in 'Software' started by Ljs, 14 Oct 2013.
  1. Ljs
    Ljs Modder
    4 Sep 2009
    Wondering if any of you could help me?
    I have a menu that looks like this:
    And here is the code:
    I now want the menu to appear like this (with some items on the right):
    But because the menu is all under the same entity (#flitering-nav) which has float:left assigned to the list, I can't for the life work out how to redo it so I can get two to float:right!
  2. faugusztin
    11 Aug 2008
    Ljs likes this.
  3. Ljs
    Ljs Modder
    4 Sep 2009
    Dude you are amazing.
    It shows how incompetent I am. I have been fiddling around with this for ages and thought I'd even tried that and I just couldn't get it to work no matter what I did.
    Much rep, I really appreciate it.
    And JSFiddle site is awesome btw!
    I hate CSS sometimes.
  4. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    either float:right
    or you could go
    #filtering-nav li a.email {
    //stuff
    that should work as well, due to specificity.
    or you could use href attribute selectors. Bunch of options. Though float:right might be the best option. Just remember to add a "clearfix" beneath, which is probably what the "clear" div is there for.
    Ljs likes this.
  5. Ljs
    Ljs Modder
    4 Sep 2009
    Thanks guys, all sorted.
    I did actually attempt what faug/you suggested by obviously didn't implement it correctly. I rarely do CSS so I seem to forget everything I have learnt and spend a lot of time scratching my head. So frustrating!
