Cubic zion [Updated PAG 4 (14/05) HoT!!!]
Discussion in 'Project Logs' started by Neo4, 16 Oct 2004.
  1. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    4!!! res'.. :jawdrop:
    nice mod definetly, i love the cube design many are adopting lately
    Good Work
  2. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    That looks really good! just steatlh the cd drives with some aluminium and will look cool :D
  3. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    looking really nice, hope you do a good job with the drives, maybe keep the fascia shape instead of doing two the same?! How many reservoirs does a guy need?!
  4. Neo4
    Neo4 What's a Dremel?
    15 Oct 2004
    hy guys :)
    ey thanks a lot :thumb: :thumb: :thumb:
    i'm searching some ideas to what to do in alu co cover the cds i'm tinking on some like the coolermaster or lian-li fronts to cover the cds of their cases :)
    i think that one res is important to put the water and to take off the water but i have 4 because i think is prety cool the res :D :D
    see you and thanks one more time[]
  5. cool_dude
    26 Aug 2004
    stealth the cd's yourself. Dont go and buy a CM or lian li one....
    Get 2 pieces of aluminium and use double sided tape and there :) Then your case will be 100% own made ;)
  6. Neo4
    15 Oct 2004
    yeah but i want the cds with a buton to open not only open by software :rock: i must find somehow to do that.
    see u
  7. Neo4
    15 Oct 2004
    hey guys,
    i'm back again :rock:
    i've made some changes to my project. now it has an nec 3500a silver and the other dvd is still with the normal color (i will paint it)
    i've puted an 320x240 graphic lcd on the front, and a blue anti-vandalism button from aqua-computer.
    i will post more pics when my new sistem arrives:
    asus an8 sli
    amd 3500+
    2x512 ddr 400
    xfx 6600gt
    and the respective waterblocks for the cpu, gpu and chipset
    stay connected :dremel:
  8. <A88>
    10 Jan 2004
    yay! :D can't wait to see it back mate :dremel:
    <A88>
  9. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    that case looks pretty awesum
    n1
    - S
  10. deadly-app
    deadly-app What's a Dremel?
    9 Mar 2004
    4 res's :lol:
    looks sweet tho :p
  11. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    my opinion?
    RESERVOIR OVERKILL!!!!!
    why dont you put the whole pc in water?
    this just kills the beauty of a nice reservoir
    i say get out with the top one
    and your drive res
    and keep your pillar ones
  12. Neo4
    15 Oct 2004
    okay it's tour opinion, i like very much the 4 res.they give style to the case :rock:
  13. <A88>
    10 Jan 2004
    Yeah I can't see a problem with it tbh- water looks cool afterall :D
    <A88>
  14. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    looks sweet!!! what u planning to do with the stacker then? i've jsut started work on mine, don't no weather to do a project log tho!
    and where do you get the software from to open CD drives?
    Thanks
    Good work :D
  15. Neo4
    15 Oct 2004
    the stacker project is still off. when i finish this one i will begin with stacker.but it will be a soft mod not and hard core :D
    when we talked by software is going to the my computer and on the drive choose eject...
    tnhks a lot guys[[[]]] :thumb:
  16. jopers1986
    7 Jan 2005
    ahh i see, very good, i googled that idea and found loads of programs that puts pics on the toolbar, so u can click on them to edject the CD drives or you can set a hotkey to eject, but it is a little slow!
    thanks
  17. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    When I stealthed my drives, I used my old bezel, removed the front off my drives and stuck it directly to the tray I then put some packing where the eject button was.
    So all I have to do is to press the corner where the button was and it opened. You will just have to experiment on how much packing to use. And I also drilled holes for my led's too, but then it wasn't completely stealthed. :waah: but it still looked cool... :D
    Oh by the way awesome case.. :rock: :rock:
  18. Neo4
    15 Oct 2004
    hey []
    tnhaks a lot :D :D
    the problem with the steal is that my old dvd-reader have that sound circle and i have to take it off if i want to steal the drive.
    so i'm painting with the color of my new 3500a silver :D
  19. valkyboy
    valkyboy What's a Dremel?
    18 Jan 2004
    My compliments for the cutouts in aluminum revealing the reservoirs. First time I've seen that. I was wondering what thickness aluminum sheet stock you used?
  20. Neo4
    15 Oct 2004
    thanks a lot :) :)
    i've used 1,5mm of thickness but if it was now i would use 2,5mm...
