Case Mod - In Progress cubit upgrade
Discussion in 'Project Logs' started by mwittstrom, 18 Oct 2012.
  1. mwittstrom
    mwittstrom What's a Dremel?
    28 Jun 2007
    Got an old cubit 3 computer from 2004 I decided to upgrade.
    Most of the hardware will be replaced and the case will get a quick makeover.
    The case is made out of 5 mm alumina.
    This how the case originally looked like.
    Here is some pictures after I sandblasted the case and drilled some new ventilation holes.
    I got most of the hardware so started to put it all back together.
    On the top is the original DVD-reader. Under that is the SSD.
    No fan on the CPU cooler and I hope the single 80 mm fan in the back will be enough.
  2. Cheapskate
    13 May 2007
    I sooooo want one of those. Why are big-ass aluminum extrusions not more common.:(
  3. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    holy crap that is one rugged looking case! Excited to see where this goes :thumb:
  4. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
    I'm sure there's enough room to get a rad and some cooling blocks in there :D
    I've never heard of the Cubit 3 but I like the case and the new vent holes are a nice touch, what's the new mobo I can see USB 3 sockets is it a wi-fi board, are you keeping the original DVD drive?
  5. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Odd but nice looking :) Would make a cool email server box.
  6. mwittstrom
    28 Jun 2007
    I'm sure a rad could be squeezed in but it would be very tight. I'm going to use this computer as an htpc in my bedroom and mostly stream movies so it would a bit overkill to watercool it.
    The moderboard is a Zotac H77 ITX wifi and the CPU is an i3-3220T (TDP 35 W).
    Yes, the DVD drive is the original one, it won't be used much so no need for a new one.
  7. mwittstrom
    28 Jun 2007
    Installed XBMCbuntu and been playing with it all weekend, but too many problems so tomorrow I'm installing windows.
  8. Cheapskate
    13 May 2007
    I only just noticed the side vents were your doing. I was convinced they were factory.:thumb:
