Scratch Build – In Progress CUBO (FINAL PHOTOS page 6)
Discussion in 'Project Logs' started by Gtek, 12 Oct 2010.
  1. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    Hi everyone,
    CUBO is my fourth scratch build project and this time I decided for mini-ITX from factor, and for a couple of reasons. First of all it should complete my moddig journey from mega to mini. My frist project was massive 3 in 1 PC fully watercooled, with tons of lights in it project 3, the second was a more standard single ATX form factor pc project ULTRA and than a air cooled microATX system, project BETA which is still under construction. So now its time for even a smaller one...
    Then it comes to design I sticked to simplicity. It will be very small case, with dimensions just 20x20x21cm so I wanted to keep it simple but nice, not too complicated. Some might even say that it will be boring, but... Anyway, I also didn't want it to be very underpowered, even if it's always a challenge with this form factor, but I will try to squeeze following stuff inside. 350Watt microATX PSU, slot loading DVD writer, socket 1156 motherboard something like gigabyte GA-H35N, 2x2GB RAM, full size video card with the length up to 17cm probably ATI HD5670 and a standard HDD/SSD. And also a couple of 80mm fans to get the hot air out.
    I chose aluminium as a primary building material and some prespex for one of the walls.
    3mm dark tint prespex, which will still allow to see what's inside, but just...
    [​IMG][/IMG]
    some 1.5mm aluminium sheets to start with
    [​IMG][/IMG]
    and a couple of quick sketchup pics for rough idea of the shape
    hope you will like it :)
  2. Gtek
    10 Oct 2009
    First update, and first part coming from under my hand saw, drill and files. Still needs a few holes...
  3. jrs77
    jrs77 Modder
    17 Feb 2006
    Ah you gotta love those little miniITX cubes :blush:
    I wait for next year and the release of the new Fusion-APUs from AMD before I'll decide on building something small, but powerful. The currently available onboard-GPUs are not powerful enough for my taste and dedicated GFX-cards makes the cases still too big for my taste.
    Looking forward to the result of the Power and Reset-switches you've planned there.
  4. Gtek
    10 Oct 2009
    Yeah, I like them, I accually build this one for my self :)
    Well I was thinking about killing the reset switch and leaving just a power button, but I'm not sure yet...
  5. Gtek
    10 Oct 2009
    Looks like I'm in a right working mood today. Just finished motherboard tray. It's tiny, just 19x19cm.
  6. Gtek
    10 Oct 2009
    Another quick update.
    Mobo tray and some more part together... bottom of the larger part of the case and joining/supporting parts.
  7. Gtek
    10 Oct 2009
    Another update with more pics.
    I made the bottom of the main compartment of the case and used epoxy to joint it to mobo tray. As you can see I'm using 2 methods for joining parts in this project. Where I don't want any screws to be seen I use epoxy and for "hidden" joins and where extra strength is needed I'm using M3 countersink screw and nuts (+epoxy in some cases). Both methods are applied trough the joining parts which allows me to use thinner materials in my build.
  8. jrs77
    jrs77 Modder
    17 Feb 2006
    Ah, I don't know about the glueing tbh. I had some joints made with Araldite failing on me allready.
    Riveting or screwing is definately the way to go imho.
  9. Alexandros
    Alexandros What's a Dremel?
    10 Jan 2010
    I like the motherboard tray design :D! Also love the fact that you're using my DFI mobo design ;)
  10. Paradox42
    Paradox42 What's a Dremel?
    15 Oct 2010
    Wow, seeing lots of these miniITX projects floating around these days. (which is a good thing!) Keep up the progress, im a big fan of your project Ultra
  11. The boy 4rm oz
    10 Apr 2008
    Nice start. I really like the design, very unique and simple in appearance. It should looks great when completed.
  12. stonedsurd
    11 Mar 2009
    Nice job. Always good to see mITX scratch builds :)
  13. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    :eeek: this is awesome !
    awesome metal working skills there !
  14. Gtek
    10 Oct 2009
    Yes, I was sceptic about glueing before as well. But take Ultra, no screw or rivets at all... it really works mate...
    :D Thanks x2
    Yeah, I just had to build one :) Thanx. And I'm going to rebuild Ultra btw :thumb:
    Yes, thank you! I hope it will look good.
    Thanx mate!
    Oh thank you. I'm always jealous when I'm watching others metal working skills.
  15. Gtek
    10 Oct 2009
    Chassis is coming together. There is just last bit missing. The main compartment back wall. It is the first part I made so it just needs a few holes drilled, a couple of other tweaks and it will be ready to join the chassis. all the surfaces are sanded down and ready for primer as well.
    (I will need to do something about the photos as they become very blurry after I upload them :grr:)
  16. skullen
    skullen Minimodder
    31 Oct 2007
    Nice one Gtek,looking good :thumb:
  17. Gtek
    10 Oct 2009
    Thank you skullen!
  18. andy_mcp1
    andy_mcp1 I may have an I.D-10T error...
    14 Jul 2010
    Case is shaping nicely! Simple is often best, Ultra looked very sleek with it's clean lines! Have to admit i am always a litte envious seeing such clean builds, my material always seems to look a little tatty till the 11hour when it gets masked in paint. Top notch metal work :thumb:.
    What brand/type of epoxy are you using?
    Will be keeping an eye on this one.
  19. Gtek
    10 Oct 2009
    Hi andy, yeah it paint will fix things a lot :)
    I'm using Unibond repair power epoxy as a temporary replacement for my beloved Liquid Metal :rock:
    But it works fine, just now...
  20. Gtek
    10 Oct 2009
    I just love to make these small parts :D
