Scratch Build – In Progress CUBO (FINAL PHOTOS page 6)
Discussion in 'Project Logs' started by Gtek, 12 Oct 2010.
  1. miahallen
    miahallen Team IRONMODS - World Champions!
    5 Sep 2010
    Looks great Gtek...I'm starting to look at a scratch build for my next mini-ITX rig as well....good job so far (but not enough GPU power :D)...
  2. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    Thanx, and good luck with yours.... Yeah, I had to compromise to keep the whole thing in small.
  3. Gtek
    10 Oct 2009
    Another update, this time with chassis almost finished. Few more bits and it will be ready for the primer :rock:
  4. The boy 4rm oz
    10 Apr 2008
    The chassis looks great, very well made.
  5. jrs77
    jrs77 Modder
    17 Feb 2006
    I still wish you good luck with the glueing there of the whole backpanel-construction ;)
  6. Gtek
    10 Oct 2009
    Thanx mate!
    :thumb:
  7. jrs77
    jrs77 Modder
    17 Feb 2006
    Don't get me wrong m8. If it holds and doesn't fail after some 6-12 month in use, then more power toyou, as the constuction itself is quiet nicely done :dremel:
    I think of doing something like this for a few month now, but don't want lot's of screws nor aluminium glued together, so maybe I'm going to my local metal-worker to have some steel welded instead.
    Get's alittle bit heavier, but in SFF-size it's not as dramatic as with full ATX cases.
    Are you going to paint the aluminium afterwards?
  8. Gtek
    10 Oct 2009
    Don't know, hope it stays as it is, just now. Do you think that epoxy will degrade after some time or something? I don't expect any additional stress or load to the joins after all mounted together so I would say it will last. I mean, we will see, but...
    Yes, it will get primer, alpine white and clear lacquer for extra protection.
  9. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    looks great, but i think that you should leave it unpainted.
  10. Gtek
    10 Oct 2009
    :nono: :D
  11. Gtek
    10 Oct 2009
    I had to "improve" the fans a bit, to save some space for shell mountings :D
  12. Paradox42
    Paradox42 What's a Dremel?
    15 Oct 2010
    Nice "improvements":D
  13. Gtek
    10 Oct 2009
    :D thanx
  14. Gtek
    10 Oct 2009
    I finished the front panel a while ago, and I'm really happy that it's done. I was not really sure if I will manage to get a decent result cutting it by hand, considering the dimensions and that, and I was ready do get it laser cut, but I think I came out ok.
  15. The boy 4rm oz
    10 Apr 2008
    The front panel looks excellent, I like the vent slits you made, looks pretty precise for hand cut stuff to me.
  16. Paradox42
    15 Oct 2010
    Front panel looking nice and minimal- Me likey!:thumb:
  17. Gtek
    10 Oct 2009
    Thanx guys!
    Here is the whole sell for the shorter part of the case...
  18. IcyAero
    IcyAero What's a Dremel?
    4 Aug 2010
    Is that slot-load drive a SATA drive? If so, where you bought yours? :p
  19. Gtek
    10 Oct 2009
    Yes it's a slot load sata dvd writer, but it's actually a mini-sata and you still need an adapter if you want to use it with desktop mobo and psu... the adapter is that black thing at the back of it... and I got mine from scan.co.uk
  20. JA12
    JA12 What's a Dremel?
    3 Mar 2010
    Ehh.. it's a cube! What i carefully try to say is that I don't like the design, sorry about that :(
    Project BETA on the other hand, that's more like it :)
    And I do like the building skills on this one too. Something exotic coming with the finish?
