Scratch Build – In Progress CUBO (FINAL PHOTOS page 6)
Discussion in 'Project Logs' started by Gtek, 12 Oct 2010.
  1. k0rben
    k0rben I use my dremel as a toothbrush
    22 Jul 2010
    Great so far, just one thing - consider wrapping the wires with white electrical tape before sleeving. It will look even better :thumb:
    i love the idea, the modified fans & round sata cables :D :jawdrop:
  2. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    :duh: electrical tape, of course... I knew something's now right :D
    thanx anyway :thumb:
  3. jprykov
    jprykov New Member
    29 Oct 2010
    wow! small but terrible! i really like this one! sub'd! :)
  4. Kviker
    Kviker Member
    22 Jan 2010
    This is mdpc sleeving?
  5. Gtek
    10 Oct 2009
    (might get a slap for that :D) But no it's not I'm afraid. it's just some older stuff I had from previous builds...
  6. Gtek
    10 Oct 2009
    Well if that is true, is it worth waiting? I'm going to use HD5670 for Cubo, which is even shorter than a miniITX mobo. and you can get HD5550 and HD5570 as low profile cards... If space is an issue for you.
  7. Gtek
    10 Oct 2009
    Just a minor update... CPU cooler painted white and sleeved :)
  8. llOriginll
    llOriginll Member
    20 May 2010
    Looks absolutely sweet man, that's a pretty sick looking tiny CPU cooler there :D
  9. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    nice improvement on that cooler
  10. k.3nny
    k.3nny Active Member
    27 Jan 2010
    Cool ITX build!
    White is the new color :D
  11. DeltaFX
    DeltaFX New Member
    4 Aug 2006
    You know this journey won't end there. Sooner or later you'll realize pico-itx is not a legend...
    Nice mod.
  12. Gtek
    10 Oct 2009
    Thanks a lot guys! :thumb:
    Sure, I'm aware of pico-itx, it's just not powerful enough for me just now. But who knows, maybe I will build one based on this form factor one day :D
  13. Gtek
    10 Oct 2009
    I'm working on smaller shell at the moment, and it's almost finished. It just needs a final layer of clear lacquer, maybe some sanding ant that's it.
    one photo of how it looks just now:
  14. Gtek
    10 Oct 2009
    I just noticed :) these are not vent slits actually... they are power and reset buttons... I know it's kinda harder to tell, but I wanted to something else than typical vandal switch buttons or something like that...
  15. IcyAero
    IcyAero Member
    4 Aug 2010
    I want more shots! :blush:
    Rock on, looking epic so far :rock:
  16. k0rben
    22 Jul 2010
    :jawdrop: <-- this is me
  17. Kviker
    Kviker Member
    22 Jan 2010
    This is realy cool :)
  18. Herculess
    Herculess New Member
    5 Oct 2010
    It looks very nice, good job! What kind of paint did you use and what method (airbrush, spray..)?
  19. Gtek
    10 Oct 2009
    Thank you!
    I sprayed it with hycote double acrilic alpine white. Few thin layers with half an hour brakes between each...:thumb:
  20. JA12
    JA12 New Member
    3 Mar 2010
    Excellent photos btw. What kind of photographing gear do you use?
