Cooling Curious Question??
Discussion in 'Hardware' started by MikeTitan, 3 Sep 2003.
  1. MikeTitan
    MikeTitan Ling Ling: 273 Battle Points
    4 Mar 2003
    I forgot which company but they were advertising a spring in their tubing. I was wondering if anyone could tell me why this improves the waterflow as they advertised.??
  2. Supercool
    Supercool Gone.
    31 May 2003
    i wouldnt say it improves the waterflow, it just stops the piped kinking when you bend them.
  3. Risky
    Risky Modder
    10 Sep 2001
    The TT Aquarius kit used springs mostly because the hose was so soft it would kink at a hint of a bend otherwise.
    I think Innovatek maybe used external springs to solve the problem
  4. Timmay!!!
    Timmay!!! What's a Dremel?
    1 Mar 2002
    Thermaltake was the one I was thinking of. I know that some of the swiftech kits use a spring in a major bend for the bleed/fill kit. To prevent kinking at the bend.
