Scratch Build – In Progress CURV3D by C4B12 | 18-11-09 Painting parts
Discussion in 'Project Logs' started by C4B12, 11 Oct 2012.
  1. C4B12
    C4B12 Minimalistic PC's
    6 Oct 2011
    Haha oh yes, to much mileage. :D
    I just want to be sure it will not move, thanks.
    Does it make you sad because you miss MIPS or dont like it? I actually picked up this block from Jeremy in person when I visited Performance PCs like 5 years ago. :)
    Thanks man! Come by next time you visit Sönsvall!
  2. Cheapskate
    13 May 2007
    Mips Kit was fantastic, but hardly anyone knew about it. They kinda got washed away by the rapid expansion of everyone else in the industry.
  3. C4B12
    6 Oct 2011
    Yeah I really liked them too, glad I was able to pick my block up. The Intel version looked really good too.
  4. C4B12
    6 Oct 2011
    Another update incoming. Time to finish up the pump mount and build a IO-cover.
    I drilled holes in the bottom part of the pumpmount.
    Measured out where the holes needed to be in the acrylic as well and drilled those.
    Next part I wanted to make was a IO-cover. I started by measuring out the length of the IO as well as the widest part of it.
    I added a few mm and cut out a piece.
    I measured out where the bend needed to be and used my bending machine to do it.
    I lined up the piece over the IO too see where I needed to do cutouts. On this motherboard the only place where were the battery is.
    Cut that out with a regular metal handsaw.
    Lined it up over the IO igen and it fit except for a few mm that needed to be shaped of the bottom part.
    To mount the IO cover the left connector needed to be a bit higher.
    I solved that by cutting out two pieces, glue them together and file them down and then add it to the connector.
    The coming days I will paint all the parts, I always let that take its time as spraypainting aluminium can be difficult. I will be back when everything is painted and mounted. :)
    With kind regards,
    Johan Nyman
  5. storm-83
    storm-83 Member
    7 Nov 2014
    Nice work as always!
    Will be interesting to see temp measurements with the new watercooling gear, and looking forward to seeing the next mockup with hardware and paint!
  6. C4B12
    6 Oct 2011
    Thanks. Yeah Im looking forward to it. Temps will be posted. :)
  7. DÈF¥âÑt¸.·´¯`¤
    DÈF¥âÑt¸.·´¯`¤ Well-Known Member
    14 Sep 2004
    I'm a fan of a sexy workshop! might do some thing to mine one day :D First time ive read through this log, i can see like me you struggle to get thick plex to conform... i always shied away from bending plex that thick cause i could never get it to not to warp :(
    Loving the update :thumb: the backet needs some sanding but is a very cool idea :rock: and we have the same AEG Jig Saws!!!!
    These jigsaws are perfect for under table mounting makes cutting plex and metal a breeeeeeze :dremel:
  8. C4B12
    6 Oct 2011
    Yeah it is hard but it worked out in the end. Thanks! :)
    Im in love with AEG as well, good stuff.
  9. C4B12
    6 Oct 2011
    Time for some painting.
    Im using three cans, aluprimer, matt black paint and matt clearcoat.
    The alu-primer is highly recommended.
    Some black paint and then almost done!
    To mount the IO-cover Im using 3M's doublesided tape.
    Ended up looking like this, what do you think?
    Best regards,
    Johan Nyman
  10. kim
    kim hardware addict
    10 Jan 2016
    pretty :grin:
  11. C4B12
    6 Oct 2011
    Thank you! :)
