Hi all, i am building a custom pc, yet am unsure in the sense of component integration. i am getting these components: i5 760, £125 MSI GeForce GTX 460 Cyclone 768MB, £125 ASUS P7H55-M, £60 Corsair Builder Series CX500, £45 Antec 300, £42.85 Corsair Vengeance 4GB DDR3 1600, £53 BenQ G2220HD 22" TFT Monitor, £99.95, Samsung HD103SJ SpinPoint F3 1TB SATA-II 3.5", £38.76 Samsung SH-S223C/RSMS 22x DVD±RW SATA ReWriter, £13.98 Gelid Tranquillo CPU Cooler, £25.98 Sony Internal Multi-Card Reader/Writer 3.5" USB, £3.49 This is the list so far, would everyone agree this would work? Any advice? Thanks!
Cooling - ThermalTake Frio, very good cooler, should be around £36 HDD - Samsung F3, should be about £40 Case - Antec 300, £55 Leaving about £55 for a PSU, so something like a Corsair CX500 Oh and this is only just in your budget...
i have just re-read the spec list for the i5 760, it appears the vengeance may not be compatible? is this true?
If you need to squeeze more out of the budget the Arctic Freezer Cooling Pro 7 is a nice cooler and about £16 new from Scan.co.uk. Also, 2x2gb Corsair XMS3 1600MHz is £42 on Pixmania + £6 standard delivery. That will help make a small saving, every little helps!
swap your mobo to a P55 chipset as it better suited for i5/i7 H55 chipset is for i3 and intergrated GPUs. if you plan to overclock at all its a must. for a cooler id opt for titan fenrir or the geil tranquillo HDD is a samsung F3 1TB or 500GB version. decent set of 1600mhz RAM (same price as 1333) crosair ones are usually the cheapest from the best brands. PSU a decent 500-600W model from antec, corsair, be quiet, seasonic etc etc
Thanks, i will have a look... Thanks, i will have a look, but it says that the chip cannot support 1666, only 1333 max i think: http://ark.intel.com/Product.aspx?id=48496
It won't support 1600 without overclocking but as the price is so close between 1600 and 1333 memory you can get 1600 and leave yourself headroom for later if you're not overclocking straight away.
Basically, can i get the vengeance ram and use it "out of the box" with.. Basically, can i get the vengeance ram and use it "out of the box" with he i5 760?
Yes. If there's any trouble, the RAM can always underclock itself (check on it with CPUZ). Given that 1333MHz memory is around the same price as 1600MHz memory and either will work for you it's best if you just go for 1600MHz memory.
If you cant wait for the 5 series graphics cards to be released from Nvidia, go for atleast the standard 1gb version of the gtx460. Its more future proof. You can save money by investing in the Gelid Tranquillo if you are not heavily overclocking the CPU. And make sure your PSU has 2 PCI-E power connectors just in case your graphics card needs it.
that's a thought. the only thing is, when are they out,(i am trying to avoid the VAT rise)and are they similar price? i will look at the tranquillo. would i be right in thinking (from a noob's point of view) that i have listed all the components i need on my list above?
I would advise you getting a DVD Rewriter over a DVD-ROM for just a few quid more...it could come in handy.
Thanks EVERYONE for helping! This looks to be my final spec. I think i'll stick with msi for the gfx, for multiple reasons. Thanks again!
