Modding Custom Desk
Discussion in 'Modding' started by SJH, 8 Apr 2005.
  1. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    thats my desk. its pretty good for the price. there is even a part tp put on top of it. is handy for printer and so stuff
  2. daz_uk30
    daz_uk30 What's a Dremel?
    5 Jun 2003
    heres a pic of mine thats been stained with caustic & waxed [​IMG]
  3. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I like custom desks, you can get everything the way you want it to be, just like mine! You may want to put in features such as hooks to hold up and hide dangling wires, and put in a inbuilt cd rack or something, and all in one desk!
    I think keeping wood as it is is the best, don't laminate it, often looks cheap, don't gloss it, gets dirty easily.
  4. B.Psycho8
    B.Psycho8 What's a Dremel?
    8 Aug 2004
    Damn Daz, That has to be one of the nicest desks/setups I've ever seen, the whol look is so clean, from the wireless keyboard the the white lights from comp no desk just looks :jawdrop: for some reason. A+ lol
  5. SJH
    SJH Minimodder
    24 Dec 2003
    Well I've got it finished.
    I still need to do a bit of sanding on parts of it - I'm too lazy to do it now though :p
    There's the area to the right of my workspace. My network switch and router are hidden underneath that middle cabinet thing with the printer on :rock:
    I might add more to this desk as and when I can afford it/be bothered.
    -Sam
  6. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Looks brilliant! :thumb: That a 17" or 19"
    <A88>
  7. SJH
    SJH Minimodder
    24 Dec 2003
    The main one is a 17" LG monitor. The one to the left of the printer is a 10.4" CTX one I got for £35 on eBay :D
  8. ColD_FusSioN
    ColD_FusSioN What's a Dremel?
    26 May 2004
    thats a really good work.... you could add some additional "gadgets"... try www.thinkgeek.com...
  9. Fusen
    Fusen What's a Dremel?
    17 Jan 2004
    looks nice, aren't you going to wax it though? just take away that fresh wood look ;P
  10. scimmy
    scimmy Minimodder
    17 May 2005
    Looks good to me.. Luckily l live alone so have my PC in the lounge. l can sit on the settee with a keyboard and watch the gogglebox at the same time :)
  11. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    I like my desk:
    Simply a cheap shelf screwed into the wall to support the keyboard and mouse, and plenty of space beneath to show off the PC! :p
    (oh, and that ugly white desk with the curve in the corner was made out of cheap particle board and a few 2x2's for support! Unfortunately I can't seem to find any of that magical sticky-backed laminate stuff jazzle used...)
  12. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
    Wow, Very nice Setup!! :jawdrop:. But how do you manage to have legspace with that tower underneath.
  13. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    Im thinking that is a wireless keyboard and mouse. Either that or he is an amputee(dont mean that to be mean anyone just saying it).
    And SJH like that desk real clean and smooth. YOu gave me an idea about my desk. OH and i built my desk to ill post a pic of it later. I think mine is a bit more extreme then all the others. That is just my observation since im cocky and arrogent.
  14. infered101
    30 Oct 2004
    My desk.
    Made out of 3/4 plywood nailed together(I know nails right). The top is formica(basically counter top paperish stuff. It glues to wood and is like 1/16 inch. Coolest thing is i can cut my food on it sinces it truly kitchen countertop)
    Desk is in a mess right now since i dont feel like cleaning it up.
    Me and my dad built it and my great uncle did the drawers and front fascia(he is alot better at precise wood work which is what you need to front things and put it drawers right)
  15. Bboy_Jon
    Bboy_Jon What's a Dremel?
    28 May 2004
    i wanna build a desk
    anyone ever see the lian li desk? lol
    http://www.coolerguys.com/840556060857.html
    anyways, i kinda want one with a sliding keyboard thing, but i guess i dont REALLY need it though, i should build one
  16. frodo
    frodo What's a Dremel?
    1 Nov 2003
    i still need to build a new desk, i want something stronger and deeper, so im going to get some 10 ply, and make it so that its got some risers for my monitors (to use the space above htem better) with my amp underneath the riser.
    atm my room is SUCH a tip, ill get a picture later to showhow bad its got!
  17. scrumble
    scrumble What's a Dremel?
    18 Jan 2004
    Seeing has how everybody is throwing their home made desks into the ring :cooldude: :
    The 'workshop'
    http://homepage.ntlworld.com/scrumble/images/desk/desk002.jpg
    Simple stub tenons using the same groove that the panels sit. With the panels also glued into the groove its plenty strong enough and no need for full tenons or screws:
    http://homepage.ntlworld.com/scrumble/images/desk/desk003.JPG
    http://homepage.ntlworld.com/scrumble/images/desk/desk001.JPG
    Fitted and fixed. The shelf at the back was made out of the offcuts. Theres some wierd perspective thing going on in that shot, as it makes the shelf look as if its running out of level, but trust me its not.
    http://homepage.ntlworld.com/scrumble/images/desk/desk004.JPG
    And the most important design feature. Two doors underneath the desk hide the sockets and all the nasty wires :)
    http://homepage.ntlworld.com/scrumble/images/desk/desk006.jpg
    Cosy fit. With the sponge for extra sound proofing its virtually noiseless, but due to heat building up the main rigs ended up on top of the desk. Which isn't the end of the world, as the only time the fans are cranked up is for games, and I usually wear headphones then :) :
    http://homepage.ntlworld.com/scrumble/images/desk/desk005.JPG
  18. frodo
    1 Nov 2003
    Damn, im liking that desk man, it looks good
  19. scrumble
    18 Jan 2004
    Well, its not bad for a rush job, managed to fit it in over a bank holiday :)
    I'd already made the top and the panels months ago, and they'd been cluttering up the garage, so I had to finish it to get the car in there
    Edit: BTW thanks for not taking the p*** out of my wallpaper :)
  20. UnkleRosco
    UnkleRosco What's a Dremel?
    4 Jul 2005
    Here's my custom desk, well its the GFs.. Built it for her a while back...
    Check out www.custompc.co.uk n check out the readers drives section
