Electronics Custom extension
Discussion in 'Modding' started by jamsand, 12 Feb 2015.
  1. jamsand
    jamsand Well-Known Member
    21 May 2011
    Hey guys I've got the sleeving part down what I'm not sure about is what wire to buy when making a 24-pin extension. I know I'll need a male and female 24-pin but recommended cable lengths just to go from the back of the case round to the front would be nice. The build is in a fractal R3.
  2. Meelobee
    Meelobee New Member
    5 Nov 2003
    Which pins you need depends on the PSU you have, some modular ones use female pins on both ends of the wiring.
    Most used wire is 18AWG. Cable lenght you'll have to measure as it's different depending on your hardware/layout.
