Modding Custom Made Functional Art Piece
Discussion in 'Modding' started by GSTMAN, 3 Feb 2014.
  1. GSTMAN
    GSTMAN What's a Dremel?
    14 Jan 2014
    I have just completed my project of building a computer that is inside of, what is basically, a custom made shadow box/ picture frame. I like the idea of letting the computer components speak for themselves. From the motherboard's complex circuits, to the simple exterior of a HDD, I have always felt it is such a shame to tuck these beautiful parts away into a computer case or worse, ruin them in a gaudy case that still just ends up under a desk. Art is meant to be hung on a wall for display. And that is exactly the idea that I'm trying to bring to life. I have installed Battlefield 4 to check out how well it could handle it and to keep an eye on temps. After playing with all but a couple of settings all the way up for about an hour or so the CPU's highest recorded temp was 39.5C, GPU max was 53C. The motherboard has 3 sensors, highest was was 47C.
    Specs:
    This computer was built for mid-high performance. I wanted this computer to have a least some bite to live up to its bark.
    Video Card:
    XFX AMD Radeon HD 7750
    Chipset: AMD Radeon HD 7750
    Video Memory: 1GB GDDR5
    Memory Interface: 128-bit
    Bus: PCI-Express 3.0 x16
    Max. Resolution: 2560 x 1600
    Connectors: DVI-I, HDMI, DisplayPort
    CPU:
    FX-8320 FX-Series 8-Core Black Edition
    Frequency: 3.5/4.0GHZ (Base/Overdrive)
    Cores: 8
    Cache: 8/8MB (L2/L3)
    Socket Type: AM3+
    Power Wattage: 125W
    RAM:
    G.Skill DDR3 PC3-12800 RipjawsX Series
    8GB DDR3 PC3-12800 Dual channel kit 2x4GB
    1600MHz CL9 (9-9-9-24)
    Hard drive:
    Seagate Barracuda 7200
    1.5 TB
    7200RPM
    SATA 6 Gb/s
    64MB
    Power Supply:
    OCZ ModXStream Pro 600W Modular High Performance Power Supply
    And here is a video of one of the LED light strips' settings.
    https://www.youtube.com/watch?v=lAxg8qdXyZU&feature=c4-overview&list=UU7wCgE7Vh0aMRps6s3jZuXw
    Thank you,
    Scott Y.
  2. spolsh
    spolsh Multimodder
    4 Feb 2012
    Watching the vid, I like it most with the red LED's.
    Has the front panel been changed for the last photo ? Looks tons better with the darker looking surround.
