Guide Custom Modular Power Cables
Discussion in 'Modding' started by Captain Slug, 16 Jan 2005.
  1. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    I did something unique and a number of people have asked that I describe the process used to make the cables in my current project.
    http://forums.bit-tech.net/showthread.php?p=850586#post850586
    Be warned however. This project takes a considerable amount of time and is extremely tedious. You will need the following tools to accomplish this.
    + Forceps or miniature pliers
    + Power Drill or Drillpress (preferred)
    + Accurate cutting tool (dremel will NOT do if you want to make spacers)
    + Soldering iron
    + Wire Cutter/Stripper
    + Accurate ruler, hopefully with metric units since you're working with parts made under them
    + Rubber mallet or hammer
    + Sharp implement for punching hole centers
    Before starting you need to source parts. The only source I could find that had everything I needed was http://www.performance-pcs.com
    Hopefully someone will know of other sources for materials in the US and UK.
    1. Cut 20 identical lengths of wire (18awg)
    2. Strip 3mm off one end of each wire
    3. Crimp on correct pins and solder/heatshrink if required
    4. Plug crimped pins into matching connector
    5. Measure connector to find outer dimensions and wire spacings
    ((The wire spacings for Molex connectors are roughly 5mm, and ATX and ATXP4 spacings are roughly 4mm))
    6. Mark measurements onto the edge of a sheet of plastic or aluminum
    7. Use an awl, ice pick, center punch, or nail with a rubber mallet or hammer to punch each hole center. Allow some spacing betwen marked connectors on the material so that you can cut them apart. Make sure to double check you measurements. something I forgot to do and subsequently ended up making spacers with 22 holes instead of 20.
    8. Drill out all the holes. 18awg wire will fit snugly through a hole drilled with 3/32-inch bit.
    9. Use a scroll saw, jigsaw, bandsaw, or table saw to cut inbetween the marked spacers
    10. Cut the spacers from the sheet
    11. Sand the edges of the newly cut spacers as desired
    12. Remove the contact paper
    13. Thread the wire through the all the spacers
    14. Straighten the cable and double check the lengths of the wires. Cut ends to match as needed
    15. Strip 3mm off the end of each wire
    16. Crimp on correct pins and solder/heatshrink if required
    ((If you are wiring a simple molex connector, skip ahead to step #19))
    17. Twist-tie one end of your stock cable. This will represent your unfinished custom cable end
    18. Using the stock cable as a template, use the resistance measurement feature on a multimeter to figure out where each wire crosses over from the connector on the other end. Make the same cross-overs on the end of your custom cable and plug the pins into those connector sockets.
    19. Plug remaining crimped pins into matching connector
    20. Double-check cable voltages with a multimeter by plugging a standard color-coded extension into the end of your custom cable. Compare your voltage results with a stock cable or another power supply with the same pinout.
    Average time to complete
    ATXP4 cable: 2+ hours
    Molex 4-pin cables: 4+ hours
    ATX cable: 6+ hours
    As always, measure twice cut once. And more importantly double-check that you're putting the pins where they belong. They're a real booger to get back out if you screw them up.
  2. Shadowcaster
    Shadowcaster New Member
    31 Dec 2004
    Nice, I wonder if that same concept could be used on old style IDE cables. That would be pretty nice.
  3. Captain Slug
    25 Nov 2001
    You'd simply need to take apart the heads and replace the wires.
  4. Wrigley1
    Wrigley1 New Member
    5 Dec 2004
    Nice cable! Sooo...
    Basically what we're making here is a replacement cable for a modular power supply that isn't color coded and has spacers between the wires to make them neater? This is pretty simple for a standard molex connector... 4 hours seems like overkill. 4-6 hours for the ATX-20-pin connector, now, I could buy that, but, for the molexes... did you take breaks or something? :eyebrow:
  5. Captain Slug
    25 Nov 2001
    Here's a better picture of the finished ATX cable
    I'm slow and methodical and that's not a measure of time per cable. It does however takes alot of time to machine that many spacers.
    Your results will vary depending on what tools you have access to.
    The guide could very well be applied to a regular power supply if you were adventurous enough to completely rewire one. You also DO NOT have to use the same shape of spacers that I did. On another forum someone suggested round spacers or bundled/clear sleeved wired. That would also be very attractive. I didn't try it because the wire I'm using is rather stiff.
  6. Wrigley1
    Wrigley1 New Member
    5 Dec 2004
    Ahh. I understand. I was thinking, "gee, replacing the wires shouldn't take 4 hours..." hehe.
    That blue cable looks so much better than my multicolored blob! I am planning on doing "extensive" modding on my next project, and this might be a solution to sleeving the wires. I might try the rounded spacer look though. Good guide.
  7. Tech-Daddy
    Tech-Daddy New Member
    8 Oct 2003
    Ooo.... oooo...
    Thankyou... thank you.... thank you.... OOoooo
    Master Cable Craftsman! (Sounds like a bad pr0n movie...)
    Kidding....
    Inspiration comes in many forms, and you my friend have inspired me!
    Looks like part of my christmas gift cert to Home Depot is going to fall onto a drill press!
    Been looking for a good excuse... now I have one!
    :thumb: :thumb: :thumb: :thumb: :thumb:
  8. nothingtrend
    nothingtrend New Member
    19 Jan 2004
    I actually did this to my psu at one point and in the process of testing some led lighting, one of the cats knocked my forcepts into the psu and fried it, havnt had the patience to redo it yet on a new psu, im really diggin the spacers on this though, may have to borrow the idea =)
  9. Captain Slug
    25 Nov 2001
    Drillpress = Best tool ever
    My drillpress sees more use than any other tool in my workroom and it's also the safest and easiest to use. Last month I got a 4" sanding and buffing wheel for $8 now and my drillpress doubles as a power sander.
  10. Pelihirmu
    Pelihirmu New Member
    2 Jan 2005
    Wow :baby: That PSU looks really nice now :thumb: :p
  11. mediacoretex
    mediacoretex New Member
    28 Feb 2005
    eww a ultra power supply :D
    jk good job
  12. MrDT
    MrDT fapfap
    14 Jun 2002
    any idea if the gauge of wire used is important on ide ribbons? also, does the length of each wire in a ribbon have to be exactly the same length, or is there room for minor mistakes?
    sorry, i know this thread is for psu's, but this might just help me out quite a lot :thumb:
  13. emesdee
    emesdee New Member
    13 Feb 2005
    I'm pretty sure its 28awg.
  14. ehrnam45
    ehrnam45 New Member
    5 Jul 2004
    i'm assuming that there is very little tolerance for length differences. I'm not too current on ATA133 cables, but from what I know, the reason they used ribbon in the first place is because every other conductor is a ground/earth line, to assist in shielding and crosstalk issues. I'm assuming that you intend to wire your own rounded IDE cables? I think that might require a jig or something to hold the wires in place while you apply the connector. If i'm not mistaken, you can use .100 pitch wire-to-board connectors. See if you can find a measured schematic of a HDD online somewhere to verify.
    I'm in the same boat for my newest monstrosity (custom power harness) but i'm not sure i will go all out with new wires. I just want to make it modular.
  15. MrDT
    MrDT fapfap
    14 Jun 2002
    ok thanks :) i actually want to make a cable that will allow me to relocate a laptop drive (still using the laptop mobo). i think the best option is to hack apart a set of appropriate connectors and try to solder on a regular ribbon. i was just wondering how much problems a few mm difference in length would cause, as my soldering skills aren't all that good, and the contact points are tiny.
  16. Captain Slug
    25 Nov 2001
    You just need a 44-pin IDE cable
    http://shop.store.yahoo.com/cablesonline/2544pinidela.html
  17. ehrnam45
    ehrnam45 New Member
    5 Jul 2004
    hmm, yeah, that's prolly a lot safer :p thanks for the assist. I'm always trying to make things more complicated than they really need to be. :D
  18. MrDT
    MrDT fapfap
    14 Jun 2002
    it's not that straighforward sadly :( if you take a look in this thread, you'll see that compaq's stupid custom connectors are causing me a bit of trouble.
    again, i'm sorry for hijacking your thread :worried:
